Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Did not realize just the LE had that style rotor. Even his caliper guard is very different from mine!The 17 LE had the race brake installed on it.
Brake disk is not that bad, just has a small amount of alum buildup on it. First good hard application of the brakes will take care of that.
I would certainly clean that rotor up first before using!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
If both snap rings are in place, (rotor and gear in gear case) both ends of that shaft, I wonder how that rotor moved over enough to hit the caliper body?That whole brake had to wobbling like crazy? Its very possible the wedge was not seated correctly and wobbled badly and pushed out that bearing retainer ring? OR before wedge install the brake/bearing itself was not seated correctly against the tunnel/onto shaft when installing 3 bolts that hold brake to tunnel.
HABS 1
- Oct 22, 2015
- corunna,ontario
ya i dusted it off with a scotch wheel! gonna run it again tomorrow n check everything again, on another note my first ride on a winder was pretty wicked totally different than my apex, id have to say fun factor with a uncoupled is cool! from the apex i could never get transfer and even back to the no action pro action srx triple n vmax back in the day! its a blast!Did not realize just the LE had that style rotor. Even his caliper guard is very different from mine!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Its been said by Knapp and I strictly follow this.. You need to do small torques on the wedge and spin the track after each small torque until you reach you final torque.. So if your going 48 pounds i do like 4 torques just putting 10-12 pounds on and then spin track and repeat until 48lbs as example. I just set at desired number and do short torques, spinning after each one.. Make sense? Normalize the wedge on shaft
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Possible the chain case side gear is amiss? I see what your saying though!If both snap rings are in place, (rotor and gear in gear case) both ends of that shaft, I wonder how that rotor moved over enough to hit the caliper body?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
That brake pad just still looks(picture) like its not attached to the pin that holds in place.. Never seen a pad that low on the rotor?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Its a PEFI aftermarket belly pan guard, thats not a stock piece, and I'm not sure where the stock rotor guard is with the bolts in place on there. ??
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
That looks like a solid belly pan guard
Does the top mount solid also
HABS 1
- Oct 22, 2015
- corunna,ontario
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
did you check your chaincase the first time? other than that or the drivers moved im not sure. New snap ring and bearing would be on my short list of things to change out, also check to see if the snap ring groove is in good shape, but im not sure how anything like that can happen on the brake side and the chaincase not be affected, like the snap ring coming off the bottom gear, ect
HABS 1
- Oct 22, 2015
- corunna,ontario
ya i hear ya mabe i should pull chain case cover n lookdid you check your chaincase the first time? other than that or the drivers moved im not sure. New snap ring and bearing would be on my short list of things to change out, also check to see if the snap ring groove is in good shape, but im not sure how anything like that can happen on the brake side and the chaincase not be affected, like the snap ring coming off the bottom gear, ect
HABS 1
- Oct 22, 2015
- corunna,ontario
HABS 1
- Oct 22, 2015
- corunna,ontario
Kuzzy
- Dec 6, 2020
- saskatchewan
2022 STX GT
2017 King Cat M9000
well at least you have that peace of mind.....now to pulling the brake caliper and seeing what is going on with the bearing......unless somebody has a better idea, that is what i would do lol.
drive chain looks tensioned enough? not whipping around or anything?
HABS 1
- Oct 22, 2015
- corunna,ontario
ya i pulled that complete assembly yesterday, removed bearing totally , greased it reinstalled it put clip in, figuring i was good to go lolwell at least you have that peace of mind.....now to pulling the brake caliper and seeing what is going on with the bearing......unless somebody has a better idea, that is what i would do lol.
- 7K
- 9K
