Turboflash
- Mar 18, 2019
- Southern MN
- '17 ZR9000 Ltd. PEFI Stg 3R
Here is one from this past weekend from a friend of mine. I'm glad this happened in parking lot. Minutes earlier he was out on the lake running over 100 MPH! Looks like it maybe it was cracked for a while before it broke. Took out the whole chain case (both sides). Ruined the caliper and rotor too.
2019 TCat with Hurricane 250 tune. 1-1/2" Rip2 with lots of long studs.
Wonder what causes this?
Yikes!
Lucky he has a guardian angle looking out for him....that could have gone very badly! The sled is just a sled and can be fixed.
NYTurbo
Stock or aftermarket shaft ?
Turboflash
- Mar 18, 2019
- Southern MN
All stock drive train. 24/50 gear. Was trail riding the sled all day.
Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
Happened once to an Apex in our group. Middle of the woods. Had to build a log raft to haul the sled out. We towed it with my RX1 and a Polaris tied together for about 10 miles. His had been cracked for a while too as you could the rust. He had his limiter strap pulled up a bunch and i think it left the drivers exposed to some direct hits
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
This happened to my friends 1100 turbo once. Likely the driveshaft hit something on or off trail. Rock or stump which weakened it and then it just broke some point later.
DooZ
How many miles on the sled?
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Not all pipe is created equal… looks like a flaw in that driveshaft when I enlarge the picture…
stgdz
First glad he is ok.
Second, was he running a drive shaft saver? Cuz it doesn't look like that worked
Third I remember the Ontario snowmobiler video
Lol...yes I think most of us remember that video.
I think Cat had a driveshaft issue that was supposedly fixed in 2015. Maybe the gremlins remain...
Turboflash
- Mar 18, 2019
- Southern MN
Sled has 2200 miles on it.How many miles on the sled?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2017 sidewinder ltx dx
2018 snoscoot
Wander if fitting a piece of pipe inside the driveshaft would be a good idea. While the pipe inside would not reduce torque load on the shaft it would prevent catastrophic failure. The pipe would keep everything somewhat functional by allow one cog to still have braking and one for drive.
The break seems pretty rare. And no one knows why it really broke. If it was due to cyclical fatigue caused by which is what I would hazard as a first guess, then fixing the cause is probably the answer. It would be nice to get that shaft in hand.
