fstr-thanu
- Mar 20, 2009
- Commerce Twp. MI
- 2012 Apex XTX
2010 Nytro SE
For some reason if I pull the handle slowly about half way it will stay on but if I just squeeze the Handle like i was actually stopping they flicker and then do nothing. Anybody else experience this?
2010 RTX SE with 1000mi
Thanks!
Tom
Thanks!
Tom
erosled
Replace the switch.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
The switch is under the left handlebar and held in place by one screw. Remove it from the bars then remove the two screws that hold the contact in. clean the contact with a small piece of scotch pad and reassembly it with a anti corrosion grease like Loctite dielectric grease. I had the same problem and it's a simple fix and normally doesn't require replacement.
fstr-thanu
- Mar 20, 2009
- Commerce Twp. MI
- 2012 Apex XTX
2010 Nytro SE
grizztracks said:The switch is under the left handlebar and held in place by one screw. Remove it from the bars then remove the two screws that hold the contact in. clean the contact with a small piece of scotch pad and reassembly it with a anti corrosion grease like Loctite dielectric grease. I had the same problem and it's a simple fix and normally doesn't require replacement.
Great! I'll try it tonight!
Thanks,
Tom
fstr-thanu
- Mar 20, 2009
- Commerce Twp. MI
- 2012 Apex XTX
2010 Nytro SE
Worked like a champ!
Thanks!
Tom
Thanks!
Tom
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
- 11K
