putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
I noticed on my ride today a few different times that when I went to grab the brake, it seemed very soft and after pumping quickly, it brought the pressure back up right away. This would happen very sporadically on the ride. Majority of the time it would have normal pressure and then others, just real soft....but after a quick pump the pressure would be right back normal. I never put my parking brake on either other than just changing belts.
Does this seem normal?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
If the disc is warped, or slop in the shaft and bearing they can do this. My 2012 Cat turbo was awful at doing it after a hi-speed run. Took a good two-three pumps to have brakes. My Winder only had this once last season after the bearing started spinning on the front drive shaft again. Installed the BOP wedge for this season and hopeful its gone again when it hits the snow.
putz21
- Apr 15, 2013
- Tomahawk, WI
Hmmmm. I installed the BOP wedge flush with the shaft before the start of the season and now have 3 rides in and about 250 miles so far. Weird that I just noticed this on today's ride. Hopefully it goes away.
Byam
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
can you reword, do you mean if the brake fades overnight?Hi @putz21 not normal....
Let it sit overnight whit handbrake on. If it doesn’t solved, bleed the system again...
- 8K
