Turboflash
- Mar 18, 2019
- Southern MN
Tell me again, what causes these to break? I have a 4-wheel setup in back. Once you tighten the outside bolts after aligning or tensioning the track, the axle is locked in place solid. How can there be enough force against this cheap zinc die cast part to break it?
I ordered some billet ones but don't understand why the stock ones
break?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Yeah gotta keep rear axle bolts ultra tight.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Just the way it is on some of the cheap China parts Cat used. Just not strong enough with the adjuster bolt against it, just another piece of poor engineering and parts selection from Cat.
I put GripNRip billet adjuster on mine last fall to replace the broken Cat China built ones and all is well there now. Lots of stuff to replace and go thru from the front to back on the ProCross and this is one of them as you have found.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Even whit axle tight i went through 3 set of these, viperT and SW. Material is too weak...Yeah gotta keep rear axle bolts ultra tight.
This year whit gripn rip and jt&T everything looks new after +5000km
Turboflash
- Mar 18, 2019
- Southern MN
Ok, yup 10-4. Grip-N-Rip billet ones coming.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Shoot mine never broke, three pro cross sleds, you should of kept your Japan built Apex.
RX1Jim
What are the other problems area on the Procross suspension?? Now is the time to address all of the items. Thanks.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
My stockers were fine too.....4200 miles, very tight track.
But a smart upgrade over to Grip n rip for sure.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
You guys are killing me!
10,000 miles on mine, but now i'll start to worry about it!
MO' MONEY, MO MONEY!
Crossfire12
- Feb 13, 2017
Outstanding I wouldn’t even worry about it, they will complain about the crooked staples under the seat ( don’t LOOK) ya mine where crooked, I had to make straight.You guys are killing me!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Larsen axle all the way!!Even whit axle tight i went through 3 set of these, viperT and SW. Material is too weak...
Nope the wheel washer ain’t gonna bend!
(American Bolts too!)
Not without a few hard hits tho.
Consider the track has got to pull across the rear axle........ the power of 300hp on a couple little 20mm bearings and hollow plastic wheels.....JT’s last forever new wheels going inside for next year!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
OCD, you can either worry about money or worry about reliability, but not both!
Personally I would rather worry about money.....bust out the credit card.
Turboflash
- Mar 18, 2019
- Southern MN
Seat cover staples crooked you say? I too made mine straight AFTER I had to pull the cover off to repair the seat heater element wires that broke!!! Another very poor design by Cat.Outstanding I wouldn’t even worry about it, they will complain about the crooked staples under the seat ( don’t LOOK) ya mine where crooked, I had to make straight.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I hear ya but atleast a seat heater isn’t gonna leave you stranded.
Lots of stuff is engineered like $hit nowadays, gotta just fix it.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
You just ride slow CF!Shoot mine never broke, three pro cross sleds, you should of kept your Japan built Apex.
If you plan on selling yer sled let me know, I might buy it for the wife
- 47K
