klondike22
- Mar 4, 2013
- northern New York
- 15 SR Viper LTX SE
At 1400 miles, while cruising some trails at 40 or so, I heard sharp increase in the noisy clutch noise (that has always been there), then some metallic unnatural sounds, then a super nasty scrunch racket and the track locked up and a quick stop....after some vulgar language, I realized the chaincase had a hole busted out in the bottom near the oil sight glass, oil on the trail, pieces of chain on the running boards. Lucky I was riding with a friend. Dealer has it now and will try to get me back up and out in a couple days! Good thing I have warranty!
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Dont forget about :
TRIP benefit.
Y.E.S. coverage automatically includes TRIP — Travel and Recreation Interruption Protection that's in effect from the date of Y.E.S. plan purchase, even during the factory warranty period. With TRIP, expenses related to a covered failure can be covered as well, up to $150 per occurrence. This means unexpected food or lodging expenses, transportation expenses, even a rental vehicle can be covered - and that's each time you have a covered warranty or Y.E.S. repair.
TRIP benefit.
JTSKIR222
mine went at 3800
Red Rocket
- Jan 5, 2015
- Ontario, Canada
- 2023 Yamaha Sidewinder LTX DX
Mine let loose at around 2000k
JTSKIR222
Starting to see a trend..
"Went" "let loose"? What parts failed or caused failures?
klondike22
- Mar 4, 2013
- northern New York
I was at the dealers today... the upper bearing had failed- pieces flew around inside chaincase , busted the chain apart andtore the case open on the bottom...pieces lodged in the lower gear locking the track. Under warranty, but right now is the best riding of the year! I better look into the YES business for the future!!
JTSKIR222
Ditto
sixstringorsnow
- Jan 20, 2014
- Moncton, NB
- 2014 SR Viper LTX SE
Mine did the same thing around 5600 miles. Glade I bought Y.E.S
JTSKIR222
wonder how long it will last for now...
Groomer08
Arctic cat special right there...chaincase grenading
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
FYI Arctic Cat, Yamaha or any of the manufactures do manufacture their own bearings. They all use off the shelf bearings and have bearing failures.
Groomer08
I never said they did make their own bearings.
I just stated that arctic cat is the number one chaincase failure brand.
My brother lost his on a ext580, and his buddy lost his on a pantera. Only other sled ive ever heard of a chaincase going on was a polaris. Personal experiance, no internet hearsay.
7k miles on the nytro with a broken bolt in the chaincase and it didnt grenade.
case closed.
case closed.
I remember a lot of Apex chaincase failures also way back. Do I like that wobble bearing? NO. Plan to put a better one in there this spring. Maybe Yamaha will do same. Point is we can't worry about everything. Some do fail many don't. Hopefully Yamaha takes care of those who have failure. I suspect they will. Sorry if it ruined your trip.
Caveman
- Sep 13, 2012
- New Hampshire
- Yamaha, Polaris, SkiDoo.
I've bought 20 new sleds since 1971 and have never been left stranded by a chaincase blowing up. Hopefully there's only a few defective ones out there. From the recent tones, hopefully you won't get any replies here from the sensitive Yamakumbaya sunshine crowd that letting people know about the chaincase problem is bashing and you should buy another brand.
