HABS 1
- Oct 22, 2015
- corunna,ontario
ok great thanks , iv never used yamalube mostly it was just easier to get ams oil , ill read up n make a decision wich to use
HABS 1
- Oct 22, 2015
- corunna,ontario
hello , ordering some parts and 1 being the dmc top gear, would anyone know how many tooth gear is in a 21 xtx se? also should i get the brass shift pads? thanks
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I did. no better time.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Should be 24Thello , ordering some parts and 1 being the dmc top gear, would anyone know how many tooth gear is in a 21 xtx se? also should i get the brass shift pads? thanks
HABS 1
- Oct 22, 2015
- corunna,ontario
ok , thanks, i was talking to somebody who said it probably a 21 tooth? might call a dealer to see if they can look up , hate to order wrong one
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
the LTX has a 21 top stock.. The XTX I believe to be different
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
i have not had one issue with my winder,dont get caught up into everything people post on hereThere's a million threads on here about the common issues with the Winders. A quick search will reveal. I don't think i can stomach another one!LOL
You're making the right choice! you won't regret it. I still have my 06" Attak. Had to ride it for a spell last month, couldn't wait to get back on the Winder!
WinderFab
- Mar 1, 2009
- Woodbridge, ON
8KC-E769A-41-00
DRIVE SPROCKET ASSY. (24T)
That is from Yamaha for a 2021 xtx se.
HABS 1
- Oct 22, 2015
- corunna,ontario
thanks winder fab u r correct, i emailed travis at bop to order the gear he also said it is a 24 t,also got the brass shift pads,driveshaft saver,chaincase saver,rov bypass,seat screw,hose protectors, tunnel protectors, belly pan protector,and his 4 position spring adjust blocks, just got to see what he comes up with for draining oil out of the intake trac!! thanks again
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Boy you guys got a lot of money I should sell you guys something, you guys will fall for anything, especially north of the boarder.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Any time Habs1.. you got some well needed upgrades.. just a heads up on the brass shift forks after pressing them on they will stay expanded a bit, with a pair of pliers squeeze them back together.thanks winder fab u r correct, i emailed travis at bop to order the gear he also said it is a 24 t,also got the brass shift pads,driveshaft saver,chaincase saver,rov bypass,seat screw,hose protectors, tunnel protectors, belly pan protector,and his 4 position spring adjust blocks, just got to see what he comes up with for draining oil out of the intake trac!! thanks again
HABS 1
- Oct 22, 2015
- corunna,ontario
ok rite on will do , if there anything else anyone can think of for a preventative maintenance deal on a winder im all ears! grabbed a set of duponts and orange charge tubes to just for looks lol
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
Wow, really? That is respectful. Surprised that you know where Canada is! Lol.Boy you guys got a lot of money I should sell you guys something, you guys will fall for anything, especially north of the boarder.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
You're spending all the money , you won on your Habs in the first 2 rounds !!!thanks winder fab u r correct, i emailed travis at bop to order the gear he also said it is a 24 t,also got the brass shift pads,driveshaft saver,chaincase saver,rov bypass,seat screw,hose protectors, tunnel protectors, belly pan protector,and his 4 position spring adjust blocks, just got to see what he comes up with for draining oil out of the intake trac!! thanks again
HABS 1
- Oct 22, 2015
- corunna,ontario
go habs go lol
