buying a used sidewinder
give him a break likly a bidin supporter!
I did, that's why the lol. We all know this is an expensive hobby. Just hope the supply chain is going to improve.
I always thought Quebec was all Canada, is this true educate me
OMG, get a map. In Canada we learned about other countries as well as our own.
Here's my contribution to the current direction this thread has taken....
yes thanks i just seen that sticky n bin readin the common problems, thanks, good to know about the 141 track! the one im currently lookin at is a 17 orange one, its gotva 1 3/4 back country, said clutches were machined and driveshaft machine n welded , got c&a skis fox vol shocks nd a hurricane muffler with a 330 flash, and all the stuff to support it , so it sounds to me like he has allready took care of some things
Didn't mean to hijack this thread but the Habs are hijacking the playoffs !!!!!
Did you really expect to win last night ???
im just an unedumacated truck driver, but can find my way all around the us of A and canada , damn boy! lol
hahaha go habs go! i had a early start today but habs kept me up all night , im feelin it now but its worth it!!!!
No way!
I'm using Quaker State 5-30 Ultimate Durability full synthetic. Rated right up there with the best performing oils on 540Rat blog for best wear protection. The dudes done the work and ranks the oils for wear protection. Good reading on his blog! Certain Amsoil oils are right up there too, but not all.
https://540ratblog.wordpress.com
gonna go with the same oil , grabbed a 5 litre jug at wallys today 48 bucks cdn funds, pretty decent! would anyone happen to know the preferred gear oil for the chaincase? will need to fill once i replace that top gear, i have 75 90 full synthetic i run in differential in truck wondering if thatll work?
Should. I've been using 80w90 non-synthetic gear oil for years and have never had an issue.
X2..
It will be fine to use, quantity is the most important part.
Not sure if you already picked up a used Winder or not but many of them out there have been updated by previous owners. It just a matter of asking the right questions when purchasing.
If I were is the market for a used I would look for one with updates done and maybe a 240 tune in it and be done...
X2..
ok , what would the proper capacity be? would a little xtra hurt?
got the sled out and replaced top gear,put brass shift forks , tach welded tension roller bolts, changed oil , all went well , except thats one mf of a mess to drain oil, has anyone hole sawed a hole in body underneath then used a body plug to fill to make that less messy? also noticed coolent was a bit down would like to get a jug to have on hand, spec sheet and owner manual says use a good quality ethal glycol automotive coolent, would 50/50 long life work? red stuff , or what is thd best correct stuff to get thanks
