Fleecer
- Jun 13, 2014
- 2019 SRX
Anyone know the cat # for an 88 pitch 15w hyvo chain?
I do
I don't think they offer one.Anyone know the cat # for an 88 pitch 15w hyvo chain?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Buy a 92 and knock some links out of it.
What gear combo are you trying to run ?
baggs66
- Nov 18, 2007
- chautuaqua co. n.y.
- 06 apex gt
Got mine from dave at hurricane .
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Yeah Dave can make what ever length you want.
Fleecer
- Jun 13, 2014
- 2019 SRX
Thinking about trying 42/24=1.75 ratio.
Sounds good, looks like I'll have to cut one.
Fleecer
- Jun 13, 2014
- 2019 SRX
What ratio you running in that chain?
baggs66
- Nov 18, 2007
- 06 apex gt
I'm running 21/43, 2.04 ratio, a little more dog leg than i would like but so far has worked without problems. I wanted to keep rotational weight down and not use the bigger gears and chain of the 24/50 ratioWhat ratio you running in that chain?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
problem with going these gear combos alot of time you end up with dog legs that are excessive. 2.04 ratio id run 24/50 and for fleecer id run the 21/38 both recommended ratios by Cat. not saying it cant be done .
Unless your are a drag racer looking to extract the last .001 ET, I wouldn't be the least bit concerned about that little bit of weight.I'm running 21/43, 2.04 ratio, a little more dog leg than i would like but so far has worked without problems. I wanted to keep rotational weight down and not use the bigger gears and chain of the 24/50 ratio
Also, I'm a fan of larger top sprockets since I find that these chains fit better into the teeth around them with less stress and wear.
I would like to see Cat and Yamaha fill some of the voids with sprockets and chain sizes.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
It’s on our website
baggs66
- Nov 18, 2007
- 06 apex gt
Well thats part of my problem, I'm old fat ex drag racer and rotational weight on the driveline is said to be 7 to 10lbs per lb. So it all adds up for the short and quick, not so much for the speed runner, he wanted a chain i told him where he could get it,
