Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I assume stock belt....Going to switch to 8dn?
waldo1
pretty sure thats a rexnord gear - it dosent line up correctly with the hyvo or borg warner chain and gears - different cut - i wouldnt use that 22 tooth cat gear with borg warner, stock yamaha stuff - they do not mix well.... youll have to go with the whole cat rexnord chain and gears thing - rexnord stuff is kinda junky - B W is better stuff - shouldnt mix em.
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
its a borg, heres the list and a link to a cat chart if anyone wants it.pretty sure thats a rexnord gear - it dosent line up correctly with the hyvo or borg warner chain and gears - different cut - i wouldnt use that 22 tooth cat gear with borg warner, stock yamaha stuff - they do not mix well.... youll have to go with the whole cat rexnord chain and gears thing - rexnord stuff is kinda junky - B W is better stuff - shouldnt mix em.
Borg Warner Hyvo Chain
Four Stroke Top Gears:
20T 15 WIDE 1702-423
21T 13 WIDE 1702-351
21T 15 WIDE 1702-394
22T 13 WIDE 1702-382
22T 15 WIDE 1702-395
24T 13 WIDE 1702-352
24T 15 WIDE 1702-396
http://www.arcticchat.com/forum/pinned-topic-area/339147-procross-chain-gear-info.html
MUSKOKA SIDEWINDER LTX LE
- Dec 8, 2006
- Huntsville, Ontario ,Canada
Waldo there is a Gear out there that is similar and your correct it doesn't line up but the gear that we've listed here Is Borg Warner you'll notice on packaging BW chain and gear mesh.
waldo1
no sheeeet - i ordered the rex gear with a very similar # - was wrong but ya - i believe those are correct - i ordered the 24 from yamaha - im ordering the 22 right now - its probally on back order till april.......
- Dec 8, 2006
Waldo where Are you located ? The 22 gear is very accessible here in Ontario Canadano sheeeet - i ordered the rex gear with a very similar # - was wrong but ya - i believe those are correct - i ordered the 24 from yamaha - im ordering the 22 right now - its probally on back order till april.......
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
That 24 looks inviting,yamaha has one listed in my new 2017 service manual,they have it for two of there long tracks,there 162 runs 24/50 on a 92 link chain and a 49/21 on a 90 link,just wondering if the 24/41 would be able to run a 90 link,or is that chain to long,and need an 88 link?its a borg, heres the list and a link to a cat chart if anyone wants it.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
What did Yamaha get for there 24 top gear,is it sentered metal,or hyvo?no sheeeet - i ordered the rex gear with a very similar # - was wrong but ya - i believe those are correct - i ordered the 24 from yamaha - im ordering the 22 right now - its probally on back order till april.......
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Does anyone make a 13 wide bottom gear in 40 or 39? To fit the sidewinder.
waldo1
its available but thanks - almost any gear is available from a custom shop for 10x the cost of oem - yamaha gears are cheap - like 20 - 40 bucks for top - 21 41 86 is stock on most 129, 137, 141, which is 1.95 ratio for a 9 tooth driver on rtx and ltx or about 122 mph - u can fit a 22 41 with a 86 link chain for a 1.86 ratio and get a few mph - the next chain is a 90 - borg warner does not make an 88 - but a custom shop does - u need 88 for 24 41 - which is a great option for u 141 3.0 pitch 8 tooth 1.6 lug guys, the slowest combination for top end of the group besides mtx or le deep lug slugs - smaller 8 tooth driver with 3.0 pitch changes everything - u got about a 115 mph sled. needs alot more gear with a flash. i dont like running the to the top of the gear - belts dont like that - so if u want to do 120 - u need a 125 mph gear. much better on belt...Waldo where Are you located ? The 22 gear is very accessible here in Ontario Canada
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Just bought a 38 bottom,13 wide shipped for 38 bucks,and can get a borg chain 84 pitch for 98 bucks. 38/22 gives us 141 38/21 is 135 and 41/22 131 at 8800 rpms on 9 tooth 2.86 pitch drivers.
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
We already have 21 top gear,was stock top gear on my 137 SW and I can run that with the 38 bottom,but need the 84 pitch chain,hey thanks for this chart,very helpful,i could also run 24 top and 38 bottom,on stock 86 chain,be wicked over geared though.View attachment 126664 Pretty sure you will not fit 22/38 with an 84P chain. 58-59 total teeth work with an 84P chain.
Bigger top gear is easier on the bushing from all I have found.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Ya,it might be steve,but I get better top end numbers with 21 and 38 but I can start right out now with 22/41 cause I have the 86 pitch chain.Bigger top gear is easier on the bushing from all I have found.
