Pockets
what do you guys run for chain case lube and how often do u change it?
In all my other sleds i run Klotz graphite chaincase lube and id like to in this too.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I use a good synthetic 75w90 gear oil, which happens to be the same as my truck's differential. 14k km, everything in my MP's gearcase is still original.
I've heard of people also using ATF because it's thinner (for top end speed).
Pockets
75w90 seems really thick, most specialized chain case lubes are 30wt.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
I use the Yamaha oil. It's reasonably priced and I know it works.
provfisherman
- Nov 1, 2015
- Manitoba
- 2016 Vector XTX
2015 Venture MP
I use a semi synthetic 75W90. Both semi and full synthetic 75W90 oils are considered "Arctic" oils and are approved for cold weather use. Most 75W90 oils have a pour point (just like the names suggests, it pours) of more then -40 so use in snowmobile chaincases should'nt be an issue. Also, my owners manual recommends 75W or 80W oil for use in the chaincase.
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
And its already pre-measured.
- 27K
- 12K
