chaincase leak
HABS 1
corunna,ontario
Canada
2021 xtx se,tdmax17 tune,2002 vmax 700 ss rumble pac,2001 srx hauck growlers
question, just doin some preseason maintenance,spent the better part of the day on this 21 sw.. installed a complete new clutch kit,put a bop oil tank gasket in, removed chaincase cover , inspected, adjusted, oil change etc etc, started it up all was good until it looks like my break rotor is wet... its not bk fluid, smells like gear oil ... is it possible for the magenet in the chaincase to leak by?
I would say 'yes' it's possible. I kinda was wondering same thing. Once that plastic plug with magnets has been in and out a bunch of times, does it still seal 100%?
i looked in there , it is leaking, looks like a reverse torx down at the end, i put a rag on a long extension and wiped it all out... well see how it looks in a day or 2 ... i hope i aint got pull apart the chaincase again ... ??
Had you pulled the magnet plug when you serviced? Just fill the shaft and plug the brake rotor side. Oil filled driveshaft to dampen harmonics...maybe it will quiet the clutch noise.....ha
I ususally wipe the plug and end of track shaft with acetone then apply some gasket sealer before pushing the plug in.
Don’t suggest ever removing that plug unless changing drivers or driveshaft.
