HABS 1
- Oct 22, 2015
- corunna,ontario
question, just doin some preseason maintenance,spent the better part of the day on this 21 sw.. installed a complete new clutch kit,put a bop oil tank gasket in, removed chaincase cover , inspected, adjusted, oil change etc etc, started it up all was good until it looks like my break rotor is wet... its not bk fluid, smells like gear oil ... is it possible for the magenet in the chaincase to leak by?
Turboflash
- Mar 18, 2019
- Southern MN
I would say 'yes' it's possible. I kinda was wondering same thing. Once that plastic plug with magnets has been in and out a bunch of times, does it still seal 100%?
HABS 1
- Oct 22, 2015
- corunna,ontario
i looked in there , it is leaking, looks like a reverse torx down at the end, i put a rag on a long extension and wiped it all out... well see how it looks in a day or 2 ... i hope i aint got pull apart the chaincase again ... ??I would say 'yes' it's possible. I kinda was wondering same thing. Once that plastic plug with magnets has been in and out a bunch of times, does it still seal 100%?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Had you pulled the magnet plug when you serviced? Just fill the shaft and plug the brake rotor side. Oil filled driveshaft to dampen harmonics...maybe it will quiet the clutch noise.....ha
Turboflash
- Mar 18, 2019
- Southern MN
I ususally wipe the plug and end of track shaft with acetone then apply some gasket sealer before pushing the plug in.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Don’t suggest ever removing that plug unless changing drivers or driveshaft.
HABS 1
- Oct 22, 2015
- corunna,ontario
i removed it... i had to cause it was leaking into the driveshaft,didn't take much to pop it out really, cleaned everything well and put some rtv around it and put it back in, waited a day then filled the case back upDon’t suggest ever removing that plug unless changing drivers or driveshaft.
