Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
I put 300ml amsoil or sinto+125 ml lucas stabilizer No uppergear bushing problem for me
Fast
- Sep 25, 2018
Correction its 350mlx2 dealer got an update and said it requires 300ml now wich is to the top of the sight glass
Yamatario
- Jan 8, 2009
- SW Ontario
- 2018 LTX SideWinder
2015 Viper LTX DX
2009 Nytro XTX
Don't worry about it, drive it till she blows.
This is mine 18hrs ago 91km on start of 3 day trip.
45km tow to get back to where we could pick up with trailer.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Sight glass or oil tank seal?
ApexXTX/Viper
- May 5, 2014
- 2019 SRX, 2018 Viper LTX
425 ml total should put you above the sight glass.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
The operators manual states,
"The correct level is when the lubricant is at least halfway up in the sight glass."
I read that to mean 1/2 sight glass is the minimum. Spin the track, on the stand, and see how quickly the oil disappears at 1/2 glass.
No harm, only good, will come from running to the top of the sight glass.
Mine is slightly above the sight glass. Checking level requires a 2x4 under the chain case side ski. Can just see the oil line.
At that level, while spinning on the stand, the oil still disappears from the sight glass. But I can just see a little still sloshing around at the bottom.
6500 miles on our previous XF7000/Viper, 4514 & 2500 miles on our ZR's. Knock on wood, no chain case issues so far.
Yamatario
- Jan 8, 2009
- SW Ontario
2015 Viper LTX DX
2009 Nytro XTX
At the dealer today to see what happened, but something let go inside and split the bottom of the case open and also took out the sight glass.Sight glass or oil tank seal?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Your tensioner roller wheel came off from screws falling out catastrophic failure. Mine split too, where roller wheel fell and got wedged.At the dealer today to see what happened, but something let go inside and split the bottom of the case open and also took out the sight glass.
OR your sight glass fell inward and lost oil causing catastrophic failure.
BE SURE YOUR DEALER TACK WELDS THE TWO SCREWS ON NEW ROLLER WHEEL!
https://ty4stroke.com/threads/cat-d...roller-wheel-fail.156166/page-16#post-1481800
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Mine also is to the top of the sight glass with no issue. All it is a gear lube bath like a lower unit on a boat motor
Yamatario
- Jan 8, 2009
- SW Ontario
2015 Viper LTX DX
2009 Nytro XTX
Exactly what happened...screws came out from Tension roller. All getting fixed under warranty other than loss of trip. I will tell him about the weld.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
How many miles on the sled?
Yamatario
- Jan 8, 2009
- SW Ontario
2015 Viper LTX DX
2009 Nytro XTX
7800kmHow many miles on the sled?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Yes a little! I don't really care about the sight glass "level", i just want it to stay where it belongs...lol. I know a lot of people running 500ml..,,, More than 500ml its leaking a bit from the breather( warning headers....425 ml total should put you above the sight glass.
)or a little by the trackshaft seal when really hot that's why i run 425ml in my SW. 22/41. 15W. Whit my previous viperT. 24/50-13w = 400ml
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Mobil 1 gear lube to top of sight glass.
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
Were you in QC this past weekend? Saw some one with graphics like yours. Had just broken chain case. I stopped to help but said he was ok.
