BryKlu
- Nov 1, 2017
- Presque Isle, Wisconsin
- 2010 Vector LTX GT
Friendly reminder to clean and change your belts! I just bought my sled a month ago with 5k miles and just got around to the last item...The clutch belt. Maybe I should have touched it sooner. It looked fine with a slight glazing. I noticed the sled didn't seem quite as fast as it should be and the belt would let out a squeak when letting off throttle hard then getting back on. There was a brand new spare "01" belt in the spare slot. I cleaned it with vinegar and hot water. I cleaned the clutches with throttle body cleaner and took her for a spin. Whoa...I certainly have to alter my throttle habits now. Completely unexpected. Thank you all again for the awesome advice here! ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![](/styles/vip.gif)
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
Good advice! Just cleaning your belt every season helps write a bit too. Although I put a new one on last year I lucked out and found 3 used ones for $25 at a swap meet. Each only used 1 season since the guy put a new one on every year.
