Kevin
Did an oil change on my buddy's SW last night
Engine drain plug and oil tank drain plugs were not tight at all
Not much over finger tight!
I will be checking mine before I even ride it
Use a torque wrench on both. Especially the tank. The way they use the O-ring on the bolt just squishing it is a very poor method and will really mess with feel for tightening. Engine is so small don't chance stripping it out. Ulmer and TDmax sell a easy drain kit that really works nice for the tank.
Kevin
Draining the oil tank is a pain in the A$$Use a torque wrench on both. Especially the tank. The way they use the O-ring on the bolt just squishing it is a very poor method and will really mess with feel for tightening. Engine is so small don't chance stripping it out. Ulmer and TDmax sell a easy drain kit that really works nice for the tank.
I will look at those kits
Jafo1970
You can do a search on ebay for arctic cat procross turbo oil change tool. I bought a drain rail tool for like $10 or you could make one. It goes under the drain plug and funnels the oil back down through the big floor board hole where your foot rests.
- Apr 14, 2003
- Hessel, Michigan
I use an empty quart oil bottle that has the pour spout not centered...I cut the bottle in half, the spout fits thru the floorboard and locates under the oil tank drain. No drips.
Can cut it slantways also....
Kevin
That sounds like a great idea
The easy drain you don't need tools or a funnel. Footwell stays in even.
- Apr 14, 2003
- Hessel, Michigan
I have to take the little footwell out, I can't get my hands in there to grab the bolt.
- 46K
