kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
Any body have anything that really works good on belt dust, oily films normal under hood/pannel grime? I've used dish soap, degreaser's, break clean and so far nothing really does a good job on the porous aluminum to make it look like new!
Pstn head
I used aluminum rim cleaner once and worked good, do not leave it long, spray on and rinse right away.
kviper
- Nov 7, 2003
- Oakfield WI
Never gave that a thought, maybe a mild acid?
mcamzr
Simple green works for me.
grader
castrol super clean, spray it on, hose it off, works great.
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
https://m.dollartree.com/h5/r/product/20-oz-Totally-Awesome-Cleaner/p8056/index.propro
Link for explanation. I use this stuff called awesome, my wife gets it at the dollar store. It is simply awesome. LOL! It removes belt dust, grease, oil, dirt ect.... Works great on the dull plastics also. Makes the white viper panels whiye again. I go through this stuff in the garage constantly.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
I use brake clean on the aluminum parts under the body panels. Just be careful not to get it on plastic parts as it may discolor them. G.B.
snowman 700
- Oct 10, 2005
- Mid-Michigan
- 2011 Apex SE
2012 Vector (wifes)
x2 Just don't leave it on the aluminum too long as it will cause spots. Works great on non painted tunnels also.castrol super clean, spray it on, hose it off, works great.
kviper
- Nov 7, 2003
- Oakfield WI
I will need to try a couple things. Thanks!
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Does this stain or discolor painted surfaces if not rinsed immediatly?
I need a good cleaner that i can use, but not worry about. Dont want to find out i damaged the paint because i did not rinse it off fast enough
cnybrian
- Oct 6, 2011
- Cato, NY
- 2006 Yamaha Attak
- Cato, NY
LAs Totally Awesome works great on lots of things. I spray my pants and shirts where I get grease and it comes right out in the washer, even with cold water.
Can also try Purple Power.
super1c
Moderator
- Apr 10, 2010
I use it on painted stuff all the time without any issues. Mostly garge toys but no problem so far. I haven't squirted it on my truck and left it or anything so not sure there?Does this stain or discolor painted surfaces if not rinsed immediatly?
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
Thats the answer i was looking for.. Thanks
canadianhunter
My son is a bike guy, rebuilds old bikes and built 3 custom bikes like on American Chopper. He uses vinegar on engines and aluminum to remove the stain. I think it has to be washed off quickly like the rim cleaner.
kviper
- Nov 7, 2003
- Oakfield WI
Interesting!My son is a bike guy, rebuilds old bikes and built 3 custom bikes like on American Chopper. He uses vinegar on engines and aluminum to remove the stain. I think it has to be washed off quickly like the rim cleaner.
- 24K
