putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
For the guys with 2019 or 2020 998's you don't need flash to pass to switch tunes on the fly!!
The stock handlebar gauge button is used to switch tunes
Just a heads up
The Cluster Flash is required for this to work, correct?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
YesThe Cluster Flash is required for this to work, correct?
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
@GAP Innovation
@Turbo Dynamics
Refresher question. Sled is up north so i cannot experiment to answer myself. I do not always ride with GAP app running so With flasher attached, when flash to pass button cycles through tunes does factory gauge give any indication which tune is active? OR is GAP app on phone only way to know?
After key off, on restart which Tune is active - last used, lowest, some set default, or other?
Thanks in advance
Jack
@Turbo Dynamics
Thanks in advance
Jack
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Starts on default every time key is cycled. The hour meter will show you what tune you are on when you push the button and cycle through them. No need for phone to be linked.
actionjack
- Apr 9, 2005
Thanks for the reply. Are you saying I can choose the default somehow? Or is default the lowest?Starts on default every time key is cycled. The hour meter will show you what tune you are on when you push the button and cycle through them. No need for phone to be linked.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
You setup default map within the GAP APP. Then each start, it begins on that chosen map.
A cluster flash will show the HP/MAP on window, of whichever map you are on. Handlebar switch changes it each press.
Most guys dont have both the cluster flash AND the flasher, but my sled did and it was quite versatile. Cluster flash alone works well too.
Dan
Dan
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
You don't need the dash flash to see it. I just have the button. It shows up in the hour meter just like the boost on the stock gauge.You setup default map within the GAP APP. Then each start, it begins on that chosen map.
Dan
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Which tunes were higher ?Yes sir...his stuff works great, and he’s very pleasant to deal with too.
I dynoe’d all 3 of his tunes in my sled, and 2 of the 3 dynoe’d significantly higher HP than even what Hurricane was claiming(over delivering)! And the 3rd tune was spot on what the claimed HP was advertising. So there’s no BS with their claims.
WinterWolf
- Mar 25, 2017
- Connecticut
the 225 Tune was 10 horse more at 235HP; and the 270 Tune was 5 HP more at 275HP.
The 240 was spot on at 240HP.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
True but with Dash flash it's alot more customizable and not only in HR meter. I really loved having all the features mostly cause I am abit of a geek when it comes to tech..lolYou don't need the dash flash to see it. I just have the button. It shows up in the hour meter just like the boost on the stock gauge.
Dan
