Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
The primary stationary sheave on my Winder sure gets hot quickly from the engine. Does it make sense that this heat would transfer to the belt and to the secondary and cause problems?
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Definitely not. Something else is up.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
Check all your sleds this is normal the inner sheave will be much hotter than the outer the engine does transfer a lot of heat to it. As to it transferring to the secondary I doubt it will much but some it will.
Soupy
- Jan 10, 2017
- West Michigan
Seems like a 180° engine that's next to the clutch would contribute to my 180° belt temps. I may be grasping at straws but I'm up to 13 or 14 blown belts in 2200 miles now. Clutches and belt are always hot no matter how I ride it.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
What’s your clutch setup and tune?
Soupy
- Jan 10, 2017
- West Michigan
I've tried everything. Been blowing belts since new and bone stock.What’s your clutch setup and tune?
DooZ
What has the dealer done to rectify this? Does Yami know about it? Sorry but that's freakin crazyI've tried everything. Been blowing belts since new and bone stock.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
How hot does the stub shaft get? Its not the actual crank.
Soupy
- Jan 10, 2017
- West Michigan
I could infrared it but I haven't pulled the clutch after riding so I don't know and don't have snow to test. Do you think a a viable test would be to let the engine warm up in the garage & measure the temp? Or do you think it needs to be ridden & fully warmed up?How hot does the stub shaft get? Its not the actual crank.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Honestly, these are the coolest running clutches I have owned in 6 yrs and 3 diff sleds. So this is not something I even think about.I could infrared it but I haven't pulled the clutch after riding so I don't know and don't have snow to test. Do you think a a viable test would be to let the engine warm up in the garage & measure the temp? Or do you think it needs to be ridden & fully warmed up?
Soupy
- Jan 10, 2017
- West Michigan
Lol 180 degree belt hurts fingers
Shagnos
Heading up north with my Raytek in my pocket....tools, springs, helix, shims. Enough belts to look like the Frito Bandito.........sigh
Soupy
- Jan 10, 2017
- West Michigan
Nice. I blew another belt in Munising last wknd. Constantly hot clutches & belt.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Man I feel your pain,you have the sled I had in 2013 my turbo procross was the worst sled I have ever had period!! Yours sounds like mine,but you have not blown your engine yet,i blew that to,along with chaincase and 12 belts all in 3000 miles,and I and frank belanger worked on it delegently to solve its problems.Nice. I blew another belt in Munising last wknd. Constantly hot clutches & belt.
Soupy
- Jan 10, 2017
- West Michigan
Sucks! I'm up to 13-14 belts in 2200 miles.Man I feel your pain,you have the sled I had in 2013 my turbo procross was the worst sled I have ever had period!! Yours sounds like mine,but you have not blown your engine yet,i blew that to,along with chaincase and 12 belts all in 3000 miles,and I and frank belanger worked on it delegently to solve its problems.
- 9K
