viper strike
- Dec 22, 2016
- belle plaine mn
- 2015 yamaha sr viper ltx dx
I haven't blown a belt yet.
I ran my first one for 1300 miles very little wear when changed.
At the start of a new season I replace my belt and it will last all year. Running the stockers. Does your sled have the vent in front of the primary.
SuperTurbo
- Mar 20, 2004
- Amherst, Ohio
- 17 LTXse Sidewinder
Did you get to try my secondary yet?Sucks! I'm up to 13-14 belts in 2200 miles.
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
Yup no difference. Didn't spend alot of time on it, might try again when more snow.Did you get to try my secondary yet?
Soupy
- Jan 10, 2017
- West Michigan
Yeah. I'm working on adding more venting.I haven't blown a belt yet.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Try checking motor alignment, and clutch offset, just saying
Soupy
- Jan 10, 2017
- West Michigan
Did all that long ago. I've now blown 14 belts in 2200 miles.Try checking motor alignment, and clutch offset, just saying
krm
- Apr 22, 2016
- ny
These doo vents work well 860200684
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
Holy crap!! I now have 2000 miles on my original belt and I plan on running it another 2000 miles.Did all that long ago. I've now blown 14 belts in 2200 miles.
Soupy
- Jan 10, 2017
- West Michigan
Yeah must be nice! Dealer is going to let me measure runout of the jackshaft on 1 of their new sleds tomorrow, mine has .005 and neither Yamaha or Cat has a "spec" for that so I assume any runout means that its bent, which I'm hoping is the problem with mine.Holy crap!! I now have 2000 miles on my original belt and I plan on running it another 2000 miles.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
whenever you are lost go back to the start...then go in a different direction ...if you are out of alignment...everything else is a band aid...
from what youve said...this we know for sure...
you are a bigger guy going off trail...and you think your jackshaft has run out? correct?
track and lug height? any changes from bone stock are ??
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
something is wrongSeems like a 180° engine that's next to the clutch would contribute to my 180° belt temps. I may be grasping at straws but I'm up to 13 or 14 blown belts in 2200 miles now. Clutches and belt are always hot no matter how I ride it.
there is something wrong, 14 belts!!!! there is a major malfunctionSeems like a 180° engine that's next to the clutch would contribute to my 180° belt temps. I may be grasping at straws but I'm up to 13 or 14 blown belts in 2200 miles now. Clutches and belt are always hot no matter how I ride it.
Soupy
- Jan 10, 2017
- West Michigan
Everything's good that I've found: offset, c to c, alignment, bushings, springs, etc. Not any real off trail, we hardly get enough snow in Michigan for that and certainly not this season. Jackshaft definitely has run out but haven't figured out yet what constitutes "bent". 1.25 lug, lots of changes from stock but it's been blowing belts since new and stock. Hot belt at 20% throttle.
ShootToThrill
Where in west mi are you Soup?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
what changes...forget that it did it from zero
list the changes
Soupy
- Jan 10, 2017
- West Michigan
Grand RapidsWhere in west mi are you Soup?
