1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The Hurricane tunes are wicked!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Thats exactly what I was thinking sorta...just carrying something in tool bag. I like the look of secondary with nothing on it....lolMy belt change tool is a chunk of 1 1/2" PCV pipe 5/8" long. It goes between the large flat washer and pushes on the helix as the clutch hold down bolt gets threaded in. It fits in my tool bag when not in use.
Mototown
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
I used Dave's tool today and had to take 3mm off mine to be within spec while keeping the 1mm shim behind it. I like the no float idea. If this doesn't work then that'll be the next thing I try. I do one mod at a time so I know what actually fixed it.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Agree! I need to do this more often! ..lolI used Dave's tool today and had to take 3mm off mine to be within spec while keeping the 1mm shim behind it. I like the no float idea. If this doesn't work then that'll be the next thing I try. I do one mod at a time so I know what actually fixed it.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Hurricane says it's a combination of both.
The belt running in a straight line as compared to a dogleg.
A belt running in a dogleg can be ripped in half with ease compared to a belt running in a straight line.
Straight line creates even pull across the width of the belt instead of more pull on one edge.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Just tried this setup too...works really well. Travis will like this..lol
Dan
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I talked to Hurricane they told me to set 0 float. looked at BOP adjuster and machined my own spacer instead of washers. Setup is 1.1 no float and BOP adjuster. Just did 3 winders like this and all machined secondary shafts. Now to test need snow.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Every time you change a belt with the adjuster do you have to set the deflection all over again?
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Yes but I just marked my secondary and count the turns and put it back in same location.Every time you change a belt with the adjuster do you have to set the deflection all over again?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
That's why I don't run an adjuster. I like to keep it simple.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
This has stirred the Serotonin in my now confused brain so this is where i'm at.
I have made changes already & will run it as is over New Years. I will run it until it blows then i will remove float so i know what the hell did what.
I'm not even sure if Serotonin is what's flying around up there, but something is burning......
DTR 82-27
- Dec 22, 2006
- Drumbo, ON
- 2018 SIDEWINDER S-TX DX 137
Thanks for the info 1nc 2000. I really like how simple you made it. I am gong to take off my brand new, never used belt adjuster and try your set up first this season.
Shagnos
I look forward to hearing these results.
Moodeyblue
for those that have used Hurricanes tool and made adjustment's, did you recheck the offset of the clutches and were they within factory spec?
- 6K
