Medieval racing
- Nov 10, 2015
- Saskatchewan
- 2014sr viper
I'm going to a race on the weekend and I'm having trouble setting up my clutch kit that I bought from ulmer I'm only getting 8650rpm the weights have 1 on tip 0 in mid 3 on heel and put the helix on 6/1 then tried 3/3 I lost rpm down to 8400 non turbo xtx
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Call Ulmer I just talked to Allen yesterday about mine,he's a real good guy. Left a message and returned same day.
Is it consistent? Definitely call. Either something is wrong with your clutches or maybe wrong wieghts or something. With that setup it should be over revving. You sure you arent hitting rev limiter? Are you using recall feature for those readings?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Have you checked your clutch alignment? I would be willing to bet your center to center is on the low side, or you have too much offset. Since the motor is fixed, bout all you can do is clutch around the issue. That's why some need to tweek their setup to the sled.
Rodney
- Nov 18, 2015
- Belle Ewart Ontario
- 2015 rtx se
Hey how do you get the recall feature???Is it consistent? Definitely call. Either something is wrong with your clutches or maybe wrong wieghts or something. With that setup it should be over revving. You sure you arent hitting rev limiter? Are you using recall feature for those readings?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
hold the top left button for a few seconds after a run while idleing!Hey how do you get the recall feature???
Yes it's top button of whatever side you have tach displayed. When you shut sled off it resets
Rodney
- Nov 18, 2015
- 2015 rtx se
top speed??? or rpm???Yes it's top button of whatever side you have tach displayed. When you shut sled off it resets
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
rpm there is no top speed recalltop speed??? or rpm???
