Turk
Tech Advisor
I get best top end running stock weights with & am using a Bender 48/40 with my k & n,s. It,s a very aggressive helix but for top end pulls it,s what works the best for me.
Daranello
Suspended
Turk said:I get best top end running stock weights with & am using a Bender 48/40 with my k & n,s. It,s a very aggressive helix but for top end pulls it,s what works the best for me.
Wanna come to Sudbury tune my sled....my wife make one mean Pasta
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
If it's only pulling 8600 to 8800 rpmand you're running the same top end as your stock weights at 9060 rpm you're doing great.
Remove the tip washer and middle washer to get the revs up some. You want it to run right around 9000 rpm.
8600 rpm = 104.4 mph
8800 rpm = 106.9 mph
9000 rpm = 109.3 mph
9060 rpm = 110.1 mph
Daranello
Suspended
Srxspec said:If it's only pulling 8600 to 8800 rpmand you're running the same top end as your stock weights at 9060 rpm you're doing great.
Ok I'll try that and report back..thx
What are your thought on Gearing????
- Apr 17, 2003
- Menno, SD
- Menno, SD
Leave the gearing stock on a XTX.
Daranello
Suspended
This morning I ran 111mph at 8800 mid range was 8200-8400..So I dropped the mid and tip washer and bolt (no weights) and its ran 113-114mph (speedo) at 9060rpms but the mid range may be high...it was shifting at 8600 to 8800....what do you think guys?
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
I ran stock weights on mine today, not so great conditions and could only get 107mph (speedo) @8,800rpm. Low end and mid range is nowhere near as strong as my Ulmers Super Tip setup.
SledFreak
- Feb 7, 2005
- Ontario. Canada
what does "and bold" mean? What were the conditions like?Daranello said:This morning I ran 111mph at 8800 mid range was 8200-8400..So I dropped the mid and tip washer and bold (no weights) and its ran 113-114mph (speedo) at 9060rpms but the mid range may be high...it was shifting at 8600 to 8800....what do you think guys?
Daranello
Suspended
SledFreak said:what does "and bold" mean? What were the conditions like?Daranello said:This morning I ran 111mph at 8800 mid range was 8200-8400..So I dropped the mid and tip washer and bold (no weights) and its ran 113-114mph (speedo) at 9060rpms but the mid range may be high...it was shifting at 8600 to 8800....what do you think guys?
bolt lol conditions were was like that honnycome crystals slushy stuff...like in my vid...no wind and hot
SledFreak
- Feb 7, 2005
- Ontario. Canada
Daranello said:SledFreak said:what does "and bold" mean? What were the conditions like?Daranello said:This morning I ran 111mph at 8800 mid range was 8200-8400..So I dropped the mid and tip washer and bold (no weights) and its ran 113-114mph (speedo) at 9060rpms but the mid range may be high...it was shifting at 8600 to 8800....what do you think guys?
Did you remove the weight from the heel? If so, do not do that.... You should have only removed from the tip and mid.
But 114 is not bad for those conditions. You have atleast 4-5 more if it hardens up.... Plus, on the harder run, the RPM's should increase to give more mph.... Where did you remove the bolt from, the heel? Where's the secondary at?
Daranello
Suspended
no heel is the way ulmer sent it...took out the washer and bolt from the mid and tip only....secondary at 60 degrees
think i may test with putting the mid weight back in 8600-8800 is kindov a high shift rpm isn't it??
How is yours set up??
Daranello
Suspended
Oh I forgot to add she was spuing out oil from the tank vent thru my little K&N filter
SledFreak
- Feb 7, 2005
- Ontario. Canada
Ok, Put the mid back in and try that... It should come in anywhere from 84-8600 and pull to 9000+. Like I said yesterday, it will pull more RPM as the ice hardens. This weather is killing your speed... It has been 11-14 degrees here since Sunday....Daranello said:no heel is the way ulmer sent it...took out the washer and bolt from the mid and tip only....secondary at 60 degrees
SledFreak
- Feb 7, 2005
- Ontario. Canada
Daranello said:Oh I forgot to add she was spuing out oil from the tank vent thru my little K&N filter
Probably from running in warm weather and holding it on long runs, but PM Allen about that...
enticeraised
SledFreak said:Daranello said:Oh I forgot to add she was spuing out oil from the tank vent thru my little K&N filter
Probably from running in suck warm weather, but PM Allen about that...
Mine does this on occasion when WOT
