Mountaintech
A primary spring shim does not add belt pressure, it lessens it.
Adding a primary spring shim will lessen belt grab and raise your overall rpm.
Exactly!
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
Lots of good info in this thread, Im taking notes...
8dn is only thing that stopped my belt from slipping.
stingray719
![08weight1[1].jpg 08weight1[1].jpg](https://ty4stroke.com/data/attachments/57/57179-9c2255eb4cfdf86711ab19f46917a2a8.jpg?hash=nCJV60z9-G)
Stingray what are you referring to when u say "our setup"? Is it what you're using on your sled or nospro sled? Last I ever knew was u were running stock helix, nospro, if I remember right is using a multi angle helix. Nospro is running 8fp weights? You're running 8fs? If this is so then the similarity in your setups is that you're running primary shims, but they're also different. Do you really feel that in a drag race your personal set up with flat profile weights and stock helix well beat a set up that's using aggressive profile weights and a multi angled helix that is more aggressive they are in stock? If this were true then I'm sure every single clutch vendor would be selling primary shims. I have yet to see any.
Barry, I have made it VERY clear in my posts that the heart of this is the primary clutch spring shim. Everything else helps but the heart of this is what matters. Next, an aggressive curved profile forces a quicker upshift, shift your car too fast and see if that works. Why do you think Yamaha came out with the flat profile 8fs and put it in 4 strokes? Yamaha has long had weak secondary issues, we used to (and still do in parking lots to help people) wind the secondary way tight on a Mountain Max to make a big positive difference. Both my boosted Phazers had to get roller secondary's to work right (SRX or Mountain Max secondary, IE) because the power forced early upshift on the stock secondary and bogged them down. Have to give credit for Cannondale to getting me on that path with the Phazer secondary. Thanks Cannondale!
Look at the 8fs and 8fp weights in the picture above
Now for the other part, I have been doing clutches for decades and until now all I ever saw a primary clutch spring shim do is raise engagement speed and a little on top but no real performance increase other than higher engagement speed for take off. BUT this Viper clutching setup is different. One vendor I know of who has done clutches for decades is using smaller rollers with other tweaks. If I cared I could experiment with that but I do not care to waste any more riding time testing. I have what works and why spend time trying to simplify it so I can bring it here to be bashed?
As NOS-PRO has said we don't make a dime out of this in fact I just answered another private message (and am glad too). More than a few of you I have talked to via phone and discussed clutch issues in detail. Always happy to help. Barry I am going to private message you my phone number and if you have a question lets talk about it person to person as this "drama" as it was said to me in PM isn't helping anybody.
I do not have an other than professional relationship with the vendors I recommend and sometimes wonder if those attached to a vendor via job or relatives would not be better if they stated so.
Studroes144
- Oct 30, 2013
Shifting a car too fast has zero to do with snowmobile clutching, clutching is designed to shift out the clutches as fast as possible and still maintain power at a set rpm, so the fact that I'm running more aggressive weights and a more aggressive helix than anyone I've seen yet on a stock viper and pulling 9k rpm everywhere makes me feel very confident, not to mention 1800 miles on an 8jp belt that hasn't lost a bit of performance, but let's not get u started on that again. Also, that quick winding rpm on a full load take off is the best performance for the viper, if you lug it along it doesn't launch and accelerate as quickly, this was proven to me by the stalker print outs of the clutching done last winter, the fastest times my viper ever had are when it tapped the rev limiter once or twice on the take off, why do you think Evo is doing a flash to raise the rev limiter, they explained it very clearly because the viper likes the higher rpm up top and when it hits the rev limiter it kills momentum.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I appreciate the help! From both
I have used Ulmers products and advice as well as advice from Nos Pro with great satisfaction from both.
I know Terry - Nos pro - always speaks with respect for the venders and especially Ulmers shop as he has with me.
Thanks to you all sorry we have to have these issues.
Studroes144
- Oct 30, 2013
I was just informed by a very reliable source and after doing a quick search of my own found out the stock 8gl viper weight is the same weight that's been used in the nytro since 2008. My source claimed "the 8gl is in no way a 2-stroke weight, the initial hump is to increase corner to corner acceleration" sounds like it's prolly the type of weight 90% of riders are looking for.
cacsrx1
First thing a lot of guys around here need to do is read Olav AAen's clutching hand book, and then read it 2 more times.
Studroes144
- Oct 30, 2013
Got it sitting right behind my toilet, browse thru it most every day lol. If u can read that book and understand it in just 2 attempts you're doing better than me! A lot of very in depth stuff in there
stingray719
Once again, the bump is at the heel look at the pic and see where it actually works which is at takeoff and unless you stop when going corner to corner that is not correct. 2 stroke weights historically rev at take off to make up for a lack of torque which is why I and others call it a 2 stroke weight because of the profile. Look at the chart that is pictured and see where clamping tapers off on the 8gl...ergo the hunting for rpm the stock clutch is noted for. Note the flatter curve on the 8fp. I ground the heel down on a set of 8gl just to test and it took most of the rev limiter out at take off, just as a test for myself I do not recommend this.
Note the machines the 8fs flat profile comes in.
This Yamaha 8FS-17605-00-00 WEIGHT COMP part is also used on these models and components:
2006 APEX MOUNTAIN - RX10ML PRIMARY SHEAVE
2007 APEX - RX10RW ALTERNATE DRIVE SETTING 1
2007 APEX GT - RX10GTW ALTERNATE DRIVE SETTING 1
2007 APEX MOUNTAIN - RX10MW ALTERNATE DRIVE SETTING 1
2007 APEX MOUNTAIN - RX10MW PRIMARY SHEAVE
2007 APEX MOUNTAIN SE - RX10MSW ALTERNATE DRIVE SETTING 1
2007 APEX MOUNTAIN SE - RX10MSW PRIMARY SHEAVE
2007 APEX RTX - RX10RTW ALTERNATE DRIVE SETTING 1
2007 APEX RXT ER - RX10RTRW ALTERNATE DRIVE SETTING 1
2007 ATTAK - RXW10W ALTERNATE DRIVE SETTING 1
2007 ATTAK GT - RXW10GTW ALTERNATE DRIVE SETTING 1
2007 PHAZER - PZ50W ALTERNATE DRIVE SETTING 1
2007 PHAZER FX - PZ50FXW ALTERNATE DRIVE SETTING 1
2007 PHAZER GT - PZ50GTW ALTERNATE DRIVE SETTING 1
2007 PHAZER MOUNTAIN LITE - PZ50MW ALTERNATE DRIVE SETTING 1
2007 VENTURE LITE - PZ50VTW ALTERNATE DRIVE SETTING 1
2008 APEX GT 40TH ANNIVERSARY - RX10GTAX ALTERNATE DRIVE SETTING 1
2008 APEX LTX - RX10LTGTX ALTERNATE DRIVE SETTING 1
2008 APEX LTX - RX10LTX ALTERNATE DRIVE SETTING 1
2008 APEX LTX GT 40TH ANNIVERSARY - RX10LTGTAX ALTERNATE DRIVE SETTING 1
2008 APEX MTX - RX10MTX ALTERNATE DRIVE SETTING 1
2008 APEX MTX - RX10MTX PRIMARY SHEAVE
2008 APEX MTX SE 40TH ANNIVERSARY - RX10MTAX ALTERNATE DRIVE SETTING 1
2008 APEX MTX SE 40TH ANNIVERSARY - RX10MTAX PRIMARY SHEAVE
2008 APEX RTX ER - RX10RTRX ALTERNATE DRIVE SETTING 1
2008 FX NYRO RTX - FX10RTRX ALTERNATE DRIVE SETTING 1
2008 FX NYRO RTX 40TH ANNIVERSARY - FX10MTRAX ALTERNATE DRIVE SETTING 1
2008 FX NYRO RTX 40TH ANNIVERSARY - FX10MTRAX PRIMARY SHEAVE
2008 FX NYRO RTX 40TH ANNIVERSARY - FX10RTRAX ALTERNATE DRIVE SETTING 1
2008 FX NYRO RTX NO REVERSE - FX10RTX ALTERNATE DRIVE SETTING 1
2008 FX NYTRO - FX10XL ALTERNATE DRIVE SETTING 1
2008 FX NYTRO - FX10XW ALTERNATE DRIVE SETTING 1
2008 FX NYTRO MTX - FX10MTX ALTERNATE DRIVE SETTING 1
2008 FX NYTRO MTX - FX10MTX PRIMARY SHEAVE
2008 FX NYTRO MTX 40TH ANNIVERSARY (BLUISH WHITE SOLID 1) - FX10MTRAXW ALTERNATE DRIVE SETTING 1
2008 FX NYTRO MTX 40TH ANNIVERSARY (BLUISH WHITE SOLID 1) - FX10MTRAXW PRIMARY SHEAVE
2008 FX NYTRO MX - FX10MTRX ALTERNATE DRIVE SETTING 1
2008 FX NYTRO MX - FX10MTRX PRIMARY SHEAVE
2008 FX10MTRXL ALTERNATE DRIVE SETTING 1
2008 FX10MTRXL PRIMARY SHEAVE
2008 FX10MTXL ALTERNATE DRIVE SETTING 1
2008 FX10MTXL PRIMARY SHEAVE
2008 FX10RTRAXW ALTERNATE DRIVE SETTING 1
2008 FX10RTRXL ALTERNATE DRIVE SETTING 1
2008 FX10RTXL ALTERNATE DRIVE SETTING 1
2008 NYTRO - FX10X ALTERNATE DRIVE SETTING 1
2008 PHAZER (DEEP PURPLISH BLUE SOLID E) - PZ50XL ALTERNATE DRIVE SETTING 1
2008 PHAZER (no reverse) - PZ50XL ALTERNATE DRIVE SETTING 1
2008 PHAZER (no reverse) - PZ50XW ALTERNATE DRIVE SETTING 1
2008 PHAZER - PZ50X ALTERNATE DRIVE SETTING 1
2008 PHAZER GT - PZ50GTX ALTERNATE DRIVE SETTING 1
2008 PHAZER GT - PZ50GTXB ALTERNATE DRIVE SETTING 1
2008 PHAZER GT - PZ50GTXL ALTERNATE DRIVE SETTING 1
2008 PHAZER MOUNTAIN LITE (BLUISH WHITE SOLID 1) - PZ50MTXW ALTERNATE DRIVE SETTING 1
2008 PHAZER MOUNTAIN LITE (DEEP PURPLISH BLUE SOLID E) - PZ50MTXL ALTERNATE DRIVE SETTING 1
2008 PHAZER MOUNTAIN LITE - PZ50MTX ALTERNATE DRIVE SETTING 1
2008 PHAZER RTX (DEEP PURPLISH BLUE SOLID E) - PZ50RTXL ALTERNATE DRIVE SETTING 1
2008 PHAZER RTX - PZ50RTX ALTERNATE DRIVE SETTING 1
2008 RS VECTOR (Deep Purplish Blue Metallic C) - RS90GTX ALTERNATE DRIVE SETTING 1
2008 RS VECTOR - RS90RXB ALTERNATE DRIVE SETTING 1
2008 RS VECTOR GT (Yamaha Black) - RS90RX ALTERNATE DRIVE SETTING 1
2008 RS VECTOR GT - RS90GTXL ALTERNATE DRIVE SETTING 1
2008 RS VECTOR GT 40th ANNIVERSARY (Bluish White Cocktail 1) - RS90GTAX ALTERNATE DRIVE SETTING 1
2008 RS VECTOR GT 40TH ANNIVERSARY - RS90GTAXW ALTERNATE DRIVE SETTING 1
2008 RS VECTOR LTX (Yamaha Black) - RS90LTX ALTERNATE DRIVE SETTING 1
2008 RS VECTOR LTX - RS90LTXB ALTERNATE DRIVE SETTING 1
2008 RS VECTOR LTX GT (Deep Purplish Blue Metallic C) - RS90LTGTX ALTERNATE DRIVE SETTING 1
2008 RS VECTOR LTX GT - RS90LTGTXL ALTERNATE DRIVE SETTING 1
2008 RX10LTXB ALTERNATE DRIVE SETTING 1
2008 RX10MTAXW ALTERNATE DRIVE SETTING 1
2008 RX10MTAXW PRIMARY SHEAVE
2008 RX10MTXL ALTERNATE DRIVE SETTING 1
2008 RX10MTXL PRIMARY SHEAVE
2008 RX10RTRXB ALTERNATE DRIVE SETTING 1
2008 RX10RX ALTERNATE DRIVE SETTING 1
2008 VENTURE LITE (DEEP PURPLISH BLUE METALLIC L) - PZ50VTXL ALTERNATE DRIVE SETTING 1
2008 VENTURE LITE (DEEP RED METALLIC K) - PZ50VTXR ALTERNATE DRIVE SETTING 1
2008 VENTURE LITE - PZ50VTX ALTERNATE DRIVE SETTING 1
2009 APEX (DARK RED METALLIC K) - RX10RYR ALTERNATE DRIVE SETTING 1
2009 APEX GT (DEEP PURPLISH BLUE METALLIC C) - RX10GTYL ALTERNATE DRIVE SETTING 1
2009 APEX LTX (DARK RED METALLIC K) - RX10LTYR ALTERNATE DRIVE SETTING 1
2009 APEX LTX GT (DEEP PURPLISH BLUE METALLIC C) - RX10LTGTYL ALTERNATE DRIVE SETTING 1
2009 APEX MTX (DEEP PURPLISH BLUE METALLIC C) - RX10MTYL ALTERNATE DRIVE SETTING 1
2009 APEX MTX (DEEP PURPLISH BLUE METALLIC C) - RX10MTYL PRIMARY SHEAVE
2009 APEX MTX (YAMAHA BLACK) - RX10MTYB ALTERNATE DRIVE SETTING 1
2009 APEX MTX (YAMAHA BLACK) - RX10MTYB PRIMARY SHEAVE
2009 APEX RTX (YAMAHA BLACK) - RX10RTRYB ALTERNATE DRIVE SETTING 1
2009 FX NYTRO (BLUISH WHITE SOLID 1) - FX10YW ALTERNATE DRIVE SETTING 1
2009 FX NYTRO (DEEP PURPLISH BLUE SOLID E) - FX10YL ALTERNATE DRIVE SETTING 1
2009 FX NYTRO MTX (BLUISH WHITE SOLID 1) - FX10MTRYW ALTERNATE DRIVE SETTING 1
2009 FX NYTRO MTX (BLUISH WHITE SOLID 1) - FX10MTRYW PRIMARY SHEAVE
2009 FX NYTRO MTX (DEEP PURPLISH BLUE SOLID E) - FX10MTRYL ALTERNATE DRIVE SETTING 1
2009 FX NYTRO MTX (DEEP PURPLISH BLUE SOLID E) - FX10MTRYL PRIMARY SHEAVE
2009 FX NYTRO RTX (DEEP PURPLISH BLUE SOLID E) - FX10RTRYL ALTERNATE DRIVE SETTING 1
2009 FX NYTRO RTX (YAMAHA BLACK) - FX10RTRYB ALTERNATE DRIVE SETTING 1
2009 FX NYTRO RTX SE (DEEP PURPLISH BLUE SOLID E) - FX10RTRSYL ALTERNATE DRIVE SETTING 1
2009 FX NYTRO XTX (BLUISH WHITE SOLID 1) - FX10XTYW ALTERNATE DRIVE SETTING 1
2009 FX NYTRO XTX (DEEP PURPLISH BLUE SOLID E) - FX10XTYL ALTERNATE DRIVE SETTING 1
2009 PHAZER (VIVID YELLOWISH RED SOLID 4) - PZ50YO ALTERNATE DRIVE SETTING 1
2009 PHAZER GT (BLUISH WHITE SOLID 1) - PZ50GTYR ALTERNATE DRIVE SETTING 1
2009 PHAZER MTX (BLUISH WHITE SOLID 1) - PZ50MTYW ALTERNATE DRIVE SETTING 1
2009 PHAZER MTX (VIVID YELLOWISH RED SOLID 4) - PZ50MTYO ALTERNATE DRIVE SETTING 1
2009 PHAZER RTX (BLUISH WHITE SOLID 1) - PZ50RTYW ALTERNATE DRIVE SETTING 1
2009 PHAZER RTX (VIVID YELLOWISH RED SOLID 4) - PZ50RTYO ALTERNATE DRIVE SETTING 1
2009 RS VECTOR (BLUISH WHITE COCKTAIL 1) - RS90RYW ALTERNATE DRIVE SETTING 1
2009 RS VECTOR (YAMAHA BLACK) - RS90GTYB ALTERNATE DRIVE SETTING 1
2009 RS VECTOR LT GT (YAMAHA BLACK) - RS90LTGTYB ALTERNATE DRIVE SETTING 1
2009 RS VECTOR LTX (BLUISH WHITE COCKTAIL 1) - RS90LTYW ALTERNATE DRIVE SETTING 1
2009 RS VENTURE GT (BLUISH SLIVER 4) - RST90GTYS ALTERNATE DRIVE SETTING 1
2009 RS VENTURE GT (DARK RED METALLIC K) - RST90GTYR ALTERNATE DRIVE SETTING 1
2009 RS90LGTYB ALTERNATE DRIVE SETTING 1
2009 VENTURE LITE (BLUISH SILVER 4) - PZ50VTYS ALTERNATE DRIVE SETTING 1
2009 VENTURE LITE (DARK RED METALLIC K) - PZ50VTYR ALTERNATE DRIVE SETTING 1
2010 APEX - RX10RZW ALTERNATE DRIVE SETTING 1
2010 APEX GT - RX10GTZB ALTERNATE DRIVE SETTING 1
2010 APEX GT - RX10GTZL ALTERNATE DRIVE SETTING 1
2010 APEX LTX RX10LTGTZB_L APEX LTX GT - RX10LTGTZB ALTERNATE DRIVE SETTING 1
2010 APEX LTX RX10LTGTZB_L APEX LTX GT - RX10LTGTZL ALTERNATE DRIVE SETTING 1
2010 APEX LTX RX10LTGTZB_L APEX LTX GT - RX10LTZW ALTERNATE DRIVE SETTING 1
2010 APEX MTX - RX10MTZW ALTERNATE DRIVE SETTING 1
2010 APEX MTX - RX10MTZW PRIMARY SHEAVE
2010 FX NYTRO - FX10ZB ALTERNATE DRIVE SETTING 1
2010 FX NYTRO - FX10ZW ALTERNATE DRIVE SETTING 1
2010 FX NYTRO MTX - FX10M53Z ALTERNATE DRIVE SETTING 1
2010 FX NYTRO MTX - FX10M53Z PRIMARY SHEAVE
2010 FX NYTRO MTX SE 153 - FX10M53SZL ALTERNATE DRIVE SETTING 1
2010 FX NYTRO MTX SE 153 - FX10M53SZL PRIMARY SHEAVE
2010 FX NYTRO MTX SE 162 - FX10M62SZB ALTERNATE DRIVE SETTING 1
2010 FX NYTRO MTX SE 162 - FX10M62SZB PRIMARY SHEAVE
2010 FX NYTRO MTX SE 162 - FX10M62SZL ALTERNATE DRIVE SETTING 1
2010 FX NYTRO MTX SE 162 - FX10M62SZL PRIMARY SHEAVE
2010 FX NYTRO RTX - FX10RTRZB ALTERNATE DRIVE SETTING 1
2010 FX NYTRO RTX - FX10RTRZO ALTERNATE DRIVE SETTING 1
2010 FX NYTRO RTX SE - FX10RTRSZL ALTERNATE DRIVE SETTING 1
2010 FX NYTRO XTX - FX10XTZB ALTERNATE DRIVE SETTING 1
2010 FX NYTRO XTX - FX10XTZW ALTERNATE DRIVE SETTING 1
2010 PHAZER GT - PZ50GTZB ALTERNATE DRIVE SETTING 1
2010 PHAZER MTX - PZ50MTZB ALTERNATE DRIVE SETTING 1
2010 PHAZER MTX - PZ50MTZO ALTERNATE DRIVE SETTING 1
2010 PHAZER RTX - PZ50RTZB ALTERNATE DRIVE SETTING 1
2010 PHAZER RTX - PZ50RTZO ALTERNATE DRIVE SETTING 1
2010 RS VECTOR GT - RS90GTZL ALTERNATE DRIVE SETTING 1
2010 RS VECTOR GT - RS90GTZR ALTERNATE DRIVE SETTING 1
2010 RS VECTOR GT - RS90GTZW ALTERNATE DRIVE SETTING 1
2010 RS VECTORLTXGT - RS90LTGTZL ALTERNATE DRIVE SETTING 1
2010 RS VECTORLTXGT - RS90LTGTZR ALTERNATE DRIVE SETTING 1
2010 RS VECTORLTXGT - RS90LTGTZW ALTERNATE DRIVE SETTING 1
2010 RS VENTURE - RST90ZS ALTERNATE DRIVE SETTING 1
2010 RS VENTURE GT - RST90GTZB ALTERNATE DRIVE SETTING 1
2010 RS VENTURE GT - RST90GTZR ALTERNATE DRIVE SETTING 1
2010 RS VIKING PROFESSIONAL - VK10ZB ALTERNATE DRIVE SETTING 1
2010 RS VIKING PROFESSIONAL - VK10ZR ALTERNATE DRIVE SETTING 1
2010 VENTURE LITE - PZ50VTZL ALTERNATE DRIVE SETTING 1
2010 VENTURE LITE - PZ50VTZR ALTERNATE DRIVE SETTING 1
2010 VENTURELITE - PZ50VTZ ALTERNATE DRIVE SETTING 1
2011 APEX - RX10PAL ALTERNATE DRIVE SETTING 1
2011 APEX - RX10PAR ALTERNATE DRIVE SETTING 1
2011 APEX SE - RX10PSAB ALTERNATE DRIVE SETTING 1
2011 APEX SE - RX10PSAL ALTERNATE DRIVE SETTING 1
2011 APEX XTX - RX10PXTAL ALTERNATE DRIVE SETTING 1
2011 APEX XTX - RX10PXTAR ALTERNATE DRIVE SETTING 1
2011 FX NYTRO - FX10AW ALTERNATE DRIVE SETTING 1
2011 FX NYTRO MTX SE 153 - FX10M53SAB ALTERNATE DRIVE SETTING 1
2011 FX NYTRO MTX SE 153 - FX10M53SAB PRIMARY SHEAVE
2011 FX NYTRO MTX SE 153 - FX10M53SAL ALTERNATE DRIVE SETTING 1
2011 FX NYTRO MTX SE 153 - FX10M53SAL PRIMARY SHEAVE
2011 FX NYTRO MTX SE 162 - FX10M62SAB ALTERNATE DRIVE SETTING 1
2011 FX NYTRO MTX SE 162 - FX10M62SAB PRIMARY SHEAVE
2011 FX NYTRO MTX SE 162 - FX10M62SAL ALTERNATE DRIVE SETTING 1
2011 FX NYTRO MTX SE 162 - FX10M62SAL PRIMARY SHEAVE
2011 FX NYTRO RTX - FX10RTRSAB ALTERNATE DRIVE SETTING 1
2011 FX NYTRO RTX - FX10RTRSAL ALTERNATE DRIVE SETTING 1
2011 FX NYTRO XTX - FX10XTAL ALTERNATE DRIVE SETTING 1
2011 FX NYTRO XTX - FX10XTAW ALTERNATE DRIVE SETTING 1
2011 PHAZER GT - PZ50GTAW ALTERNATE DRIVE SETTING 1
2011 PHAZER MTX - PZ50MTAW ALTERNATE DRIVE SETTING 1
2011 PHAZER RTX - PZ50RTAW ALTERNATE DRIVE SETTING 1
2011 RS VECTOR GT - RS90GTAS ALTERNATE DRIVE SETTING 1
2011 RS VECTORLTX GT - RS90LTGTAS ALTERNATE DRIVE SETTING 1
2011 RS VENTURE - RST90AS ALTERNATE DRIVE SETTING 1
2011 RS VENTURE GT - RST90GTAB ALTERNATE DRIVE SETTING 1
2011 RS VENTURE GT - RST90GTAL ALTERNATE DRIVE SETTING 1
2011 VENTURE LITE - PZ50VTAW ALTERNATE DRIVE SETTING 1
2011 VK PRO - VK10AB ALTERNATE DRIVE SETTING 1
2011 VK PRO - VK10AW ALTERNATE DRIVE SETTING 1
But I am done with this as no one I knows wants to say the 8gl is a good weight for a torque machine.
stingray719
8FP comes in these 4 strokes
This Yamaha 8FP-17605-00-00 WEIGHT COMP part is also used on these models and components:
2006 APEX ER - RX10RL PRIMARY SHEAVE
2006 APEX GT - RX10GTL PRIMARY SHEAVE
2006 APEX RTX - RX10RTL PRIMARY SHEAVE
2006 APEX RTX - RX10RTRL PRIMARY SHEAVE
2006 ATTAK - RXW10L PRIMARY SHEAVE
2007 APEX - RX10RW PRIMARY SHEAVE
2007 APEX GT - RX10GTW PRIMARY SHEAVE
2007 APEX RTX - RX10RTW PRIMARY SHEAVE
2007 APEX RXT ER - RX10RTRW PRIMARY SHEAVE
2007 ATTAK - RXW10W PRIMARY SHEAVE
2007 ATTAK GT - RXW10GTW PRIMARY SHEAVE
2008 APEX GT 40TH ANNIVERSARY - RX10GTAX PRIMARY SHEAVE
2008 APEX LTX - RX10LTGTX PRIMARY SHEAVE
2008 APEX LTX - RX10LTX PRIMARY SHEAVE
2008 APEX LTX GT 40TH ANNIVERSARY - RX10LTGTAX PRIMARY SHEAVE
2008 APEX RTX ER - RX10RTRX PRIMARY SHEAVE
2008 RX10LTXB PRIMARY SHEAVE
2008 RX10RTRXB PRIMARY SHEAVE
2008 RX10RX PRIMARY SHEAVE
2009 APEX (DARK RED METALLIC K) - RX10RYR PRIMARY SHEAVE
2009 APEX GT (DEEP PURPLISH BLUE METALLIC C) - RX10GTYL PRIMARY SHEAVE
2009 APEX LTX (DARK RED METALLIC K) - RX10LTYR PRIMARY SHEAVE
2009 APEX LTX GT (DEEP PURPLISH BLUE METALLIC C) - RX10LTGTYL PRIMARY SHEAVE
2009 APEX RTX (YAMAHA BLACK) - RX10RTRYB PRIMARY SHEAVE
2010 APEX - RX10RZW PRIMARY SHEAVE
2010 APEX GT - RX10GTZB PRIMARY SHEAVE
2010 APEX GT - RX10GTZL PRIMARY SHEAVE
2010 APEX LTX RX10LTGTZB_L APEX LTX GT - RX10LTGTZB PRIMARY SHEAVE
2010 APEX LTX RX10LTGTZB_L APEX LTX GT - RX10LTGTZL PRIMARY SHEAVE
2010 APEX LTX RX10LTGTZB_L APEX LTX GT - RX10LTZW PRIMARY SHEAVE
2010 RS VECTOR GT - RS90GTZL PRIMARY SHEAVE
2010 RS VECTOR GT - RS90GTZR PRIMARY SHEAVE
2010 RS VECTOR GT - RS90GTZW PRIMARY SHEAVE
2010 RS VECTORLTXGT - RS90LTGTZL PRIMARY SHEAVE
2010 RS VECTORLTXGT - RS90LTGTZR PRIMARY SHEAVE
2010 RS VECTORLTXGT - RS90LTGTZW PRIMARY SHEAVE
2011 RS VECTOR GT - RS90GTAS PRIMARY SHEAVE
2011 RS VECTORLTX GT - RS90LTGTAS PRIMARY SHEAVE
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The 8GL weights came in the 2008 to 2014 FX Nytro RTX and XTX models. It came in all of those models, no matter what the track option.
The 8FP weights came in 2006 to 2010 Apex & Apex LTX (121" & 136" models).
The 8FS weights came in 2006 to 2010 Apex Mtn & Apex MTX models.
The 8FS weights also came in the 2008 to 2013 FX Nytro MTX models.
Any of the other models you listed, those weights are listed as an alternate weight, that can bolt into the clutch, it does not mean they come in those models from the factory.
Studroes144
- Oct 30, 2013
I can see why they used 8fp weights in the apex, that sled is a torque monster compared to the 1049, the 1049 in the nytro/viper gets the torquey fell because of the aggressive heel on the 8gl.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Also, how can you tell that the 8GL weight "lets the engine rev" at take off or has less belt grab, I understand, maybe in your situation out in the field you felt it was that way, but was your primary spring possibly not correct? Helix selection not correct? The Yamaha chart lists the 8FP at about 450 kgf at approximately 8mm of stroke and about 320 kgf at full stroke of 30mm. The 8GL has no numbers on it's graph, but looking at the graph, it shows that it has more of a straight up (belt grabbing) graph than the 8FP or 8FS weight at the initial.
The 8FP weight has a hump/bump at the heel as well, just before the weight engages (the roller has to go over this hump/bump right at or slightly after engagement) just like it has to on the 8GL. Now the 8GL weight is approximately .020" higher hump/bump than the 8FP weight. That hump/bump applies more initial belt grab (look at the graphs, you can see the graph spike at the beginning and then slowly go down).
If you want a flat profile weight, then you better try the 8HG!
Studroes144
- Oct 30, 2013
Allen I hope you're getting overtime for this lol
