CODE 84 TPS TORS REPLACED STILL PROBLEM HELP
REPLACE TPS STILL FLASHES 84 WITH YELLOW CAUTION AFTER RUNNING AT ANY CONSISTENT SPEED FOR TOO LONG 25 MPH
50 MPH 75MPH DOES NOT MATTER TPS COVERED UNDER WARRANTY
YAMAHA DIAGNOSTIC ON DASH SAID TPS WAS OK 16 THRU 95 READING WITH NO STUTTER WHAT DO I CHECK NEXT??? HELP
2007 ATTAK WITH 12,000 MILES
I had tors coming on when you came to a stop sign . I was told by somebody here to loosen your screws on the butterflys , blip the throttle a couple of times and tighten the screws again . I did this to each , one at a time , also spraying each and my problem went away . That was two years ago . Might be worth a try ? Doc
