Does any one know a company that makes a coil over shock for a 2018 Vector 129. I have tried getting one from HYGEAR since last Feb. & also talked to them at the snow show & they can't give me a time when they will be available. I do have the upgraded fox shock on the sled but it is not reliable. (ask me why I know)
theCATman
- Feb 19, 2007
- WI
- Yamaha
Find some good take offs from a Vector or Apex. Preferably GYTR's
They will not work in that suspension. NFind some good take offs from a Vector or Apex. Preferably GYTR's
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Elka makes a replacement shock for the Singleshit rear suspension, may be your only other option.
They only make 1 for a 144 that's it.Elka makes a replacement shock for the Singleshit rear suspension, may be your only other option.
theCATman
- Feb 19, 2007
- WI
- Yamaha
Oh, my bad. I thought the front, not skid.They will not work in that suspension. N
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The 146 and 129 take the same shock when in a rs vector or apex from 2016 and on.
Here is the spring I have on our elka stage 4 shock.
Accelerated Technologies did a full service on my shock last year so they have all the info on it.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I can also confirm that the elka shock for the xtx 146 also is a direct fit in the 129. I don't know why elka does not advertise it for both. I ordered one for a customer's 129 last year and it was a direct fit. Yamaha lists same part number shock for 129 and 146 skids.
Thank you everyone for that information, I will call themI can also confirm that the elka shock for the xtx 146 also is a direct fit in the 129. I don't know why elka does not advertise it for both. I ordered one for a customer's 129 last year and it was a direct fit. Yamaha lists same part number shock for 129 and 146 skids.
Can not find that shocked listed on their website for a xtx146 for 2016-2018. Do you have a part no. Do you know what stage it is and how do you know which spring to put in.I can also confirm that the elka shock for the xtx 146 also is a direct fit in the 129. I don't know why elka does not advertise it for both. I ordered one for a customer's 129 last year and it was a direct fit. Yamaha lists same part number shock for 129 and 146 skids.
Thank's for any information.
Will a stage 4 shock fit on a 2016-2018 apex or vector. There is not a lot of room between the support bars on either side of the shock. I see they sell the stage 2 for the 2016-2018 apex or vector. What makes the stage 4 better.The 146 and 129 take the same shock when in a rs vector or apex from 2016 and on.
Since you installed this Elka shock in a 129,is there any modifications that you have to make to the suspension because of the 2 inner wheels that are mounted on the front shaft that connects the front shock mount also. Is there enough room up front so that the new shock with the coil spring doesn't hit the 2 inner wheels.I can also confirm that the elka shock for the xtx 146 also is a direct fit in the 129. I don't know why elka does not advertise it for both. I ordered one for a customer's 129 last year and it was a direct fit. Yamaha lists same part number shock for 129 and 146 skids.
Thank you for taking the time to answer my questions
Rich
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
This is on a 146.Will a stage 4 shock fit on a 2016-2018 apex or vector. There is not a lot of room between the support bars on either side of the shock. I see they sell the stage 2 for the 2016-2018 apex or vector. What makes the stage 4 better.
Had to space out the relay rods so they would clear the spring and reservoir. The reservoir is offset so it will clear the grease fitting on lower shaft.
The stage 4 has compression and rebound adjustments plus reservoir.
Buy looking at your picture I cannot see the 2 innner wheels by the lower shock mount. Does the 146 have these wheel there. When you buy the ELKA shock stage 2 does it come with larger spacers to make room for the spring.This is on a 146.
RobX-1
- Coldwater, OH
The shaft and wheels for the 146" are not located as close to the shock as the 129" does so there is no adjustments for them. However, I had problems with the OEM shaft spinning and ended up purchasing Hygear's replacement part that is needed when installing their SingleShot shock replacement on the 129" but is optional on the 146". With that said, worst case scenario is purchase this part from Hygear to deal with the shaft and wheels on the 129" and then purhcase the Elka shock you want.
