Andrew
- Nov 30, 2012
my rs vector l-tx gt ran hot yesterday, i checked the coolant and there was none in the main tank and none in the overflow tank.
So i put some in the overflow (up to the cold level mark) and i filled up the main tank. i went for a short ride and came back, the main tank was after goin down, so i topped it up again. i cant see any leaks and there was none on the floor of my shed this morning.
where could it have went? or what might cause this to happen in the first place?
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Previous sleds: 1996 Vmax600, 2007 Phazer, 2016 Bearcat 3000
Is it going in your oil??? Check your dip stick.
blue er
check your oil for coolant, if coolant in oil check waterpump then pull plugs fora look, open your panels and look closely at all hose connections including primary and rear exchangers, and make sure the overflow tube isn't broken off the bottle.
Andrew
- Nov 30, 2012
ive checked my oil and theres no coolant in it.
i was talkin to the dealer ship and they thinks my overflow cover might have came off a little bit with pressure and some might have went down over the engine. because i had a puff of steam come up around the handle bars. then i shut the sled off.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
None in the main tank seems like a lot of coolant missing. People who ride real hard develop leaks in the running board exchangers from the flexing. You might want to take a good peak at the front exchanger too.
Do a search and get the rear lifted to bleed the air out while running and then top off. It might help to get the font lifted for refilling to send most of the air to the main tank before the bleed. To bleed undo the 2 nuts inside the tunnel on one side of the plastic trim covering the bleed bolt. That will give you enough freedom to access the bolt.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Curious, what year is your Vector?
I installed a rear heat exchanger on mine last summer and the only tank I noticed was the small one with a cap just under the panel between my handle bars and windshield.
I did remove the coolant hose on the left side below the secondary, raised sled front and rear and got most out I believe then refilled it via the small tank again.
After my first ride of the season, after making sure I got most of the air out of during the refill, I only had to add a bit more.
My is an 08 Vector carbed.
Andrew
- Nov 30, 2012
i got the Rs Vector L-Tx GT its 2010. under the panel between the handle bars and windshield i had two tanks there.
sledneck22
There could be a hole in a line somewhere above the motor and burning off while running. I had a 1/4" diameter stick go between my air intake plenum and headlight. It poked a hole in the 3/4" hose by the fuel rail. It would leak onto the engine and burn off. Never left a puddle. I thought it was a fluke accident but who knows!!! might even pay to pressure test the system with panels off to find the leak. It's obviously going somewhere!
Yamahammer485
Andrew said:my rs vector l-tx gt ran hot yesterday, i checked the coolant and there was none in the main tank and none in the overflow tank.
Is it new or used? If its used, its entirely possible the previous owner did something with the coolant and its not up to total voulme. When changing mine, it took a while for it to accept the 6+ liters of coolant.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Andrew said:i got the Rs Vector L-Tx GT its 2010. under the panel between the handle bars and windshield i had two tanks there.
Interesting. Anyone have an answer to this?
Thanks for the info.
actionjack
- Apr 9, 2005
I was surprised when you posted you didn't have an overflow tank so I looked in the parts fiche - sure enough the overflow tank shows up on the Vector 1 year after yours.Irv said:Andrew said:i got the Rs Vector L-Tx GT its 2010. under the panel between the handle bars and windshield i had two tanks there.
Thanks for the info.![]()
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
actionjack said:I was surprised when you posted you didn't have an overflow tank so I looked in the parts fiche - sure enough the overflow tank shows up on the Vector 1 year after yours.Irv said:Andrew said:i got the Rs Vector L-Tx GT its 2010. under the panel between the handle bars and windshield i had two tanks there.
Thanks AJ, was thinking my vision was worse than I thought and I was really questioning myself how I couldn't have seen it?
