hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
How did Yamaha make up for the lost rad and fan? Can't find any pics or info.
MitchellNytro
I am also a bit concerned about this, especially with the XTX and BTX models that may not get enough snow if used on a trail to cool a high hp turbo engine.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I did testing on my viper with rad removed. In snow it stayed cool. Once stopped it heated up very fast.
DC5
I would assume they have tunnel coolers like the turbo cats
They have new added tunnel coolers and rear cooler.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Is a tunnel cooler up above the track or ??? I'm familiar with a cooler in front of the tunnel, also in the rear of the tunnel as well as running board coolers.
theCATman
Yes. Usually two thin ones that line up with the windows in the track as to not get hit by studs.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
K thx!
so we will get ice build up on new sidewinder and how about oil spillage when you tip one over is that still a problem
theCATman
Not likely on the ice. It's the exhaust pipes & muffler that causes most of the build up on Apex, Vector, Nytro, Phazer, RX1, etc.so we will get ice build up on new sidewinder and how about oil spillage when you tip one over is that still a problem
This will exit lower right, same as Viper.
Sent from my SCH-R970 using Tapatalk
You hit it on the head.
morepower=morefun
- Nov 16, 2015
- Upstate, NY
- SR VIPER Turbo by Ulmer Racing, NYTRO XTX Ulmer Racing Stage 4
Dual heat exchangers connected as tunnel protectors. Normal one in front is same, then rear is flat mounted toward rear of tunnel but stops before tail light, does not curve down like old rear exchangers. ***** Just rode my Viper 70 miles tonight on extremely marginal conditions. (rock hard icy base with under an inch of fresh snow) Sure was glad my Viper has radiator and fan... got hot 3 times, just turned key to acc. and let fan cool it down in a minute or two. Sidewinder will take a hell of a lot longer to cool down if it gets hot.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
SW also has the oil spraying up at the pistons .Dual heat exchangers connected as tunnel protectors. Normal one in front is same, then rear is flat mounted toward rear of tunnel but stops before tail light, does not curve down like old rear exchangers. ***** Just rode my Viper 70 miles tonight on extremely marginal conditions. (rock hard icy base with under an inch of fresh snow) Sure was glad my Viper has radiator and fan... got hot 3 times, just turned key to acc. and let fan cool it down in a minute or two. Sidewinder will take a hell of a lot longer to cool down if it gets hot.
This sounds helpful .
Has anyone done that b4 ?
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I've seen oil nozzles under the pistons in automotive engines so this s not something new. I know that Toyota has them in their engines because I rebuilt one last year. This is from the Toyota manual.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Yamaha and Toyota are pretty tight , so that probably has something to do with it being on this engine , and it works .I've seen oil nozzles under the pistons in automotive engines so this s not something new. I know that Toyota has them in their engines because I rebuilt one last year. This is from the Toyota manual.
Each may be a minority stock holder in the others business .
No snowmobile engine has that feature ?
