jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Time for a big cigar !!
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I was going to say a good epoxy does wonders! I have used epoxy in race engines and ground into it to make ports bigger in cases and cylinders. I've never seen epoxy fail when its prepped properly. Amazing stuff!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
This guy had a small fire from oil leaking from cracks. Oil was pooling up under the muffler.(probably saturated foam)
20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
As much as I go on about the YamiCats sleds I hope you guy's get fixed up and are back on the trails soon, don't like seeing anyone missing trail time and planed sled trips.
vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
Fixed mine over the last two days. I could not use the 3mScotch Weld as planed. I left it in the garage and had froze sometime since the fall of 17 when I did the rear heat exchanger protectors. I bought Devcon brand 2500 pound epoxy at the local hardware store. Applied a liberal amount to the crack inside chain case and smoothed it out once it started to set up. Allowed 12 hrs to set and cure, added a coat of Ultra Copper RTV today and buttoned up the chain case. Getting fluid on Tuesday at the local dealer, finish the button up and run her on the stand. I hope this fix will get me thru the season.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
over torqued bolts?View attachment 158750 View attachment 158751
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
over torqued bolts?
Must be?? sled is a 2020 and had 600km . Oil tank has never been openedover torqued bolts?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Tank never opened? That changes things a little.. Could be something from factory.. Or even a casting issue with this magnesium.. Obviously they have issues with it..Must be?? sled is a 2020 and had 600km . Oil tank has never been opened
RAMSOMAIR
Devcon is some really good stuff. We used to use it to repair chutes at the cement plant. Case is junk. Too thin, garbage material and a lot of flexing. Needs to be aluminum not magnesium.
vodoo child
- Oct 29, 2005
- Palmerton Pa.
Buttoned up the chain case, filled with 16ozs. of fluid and ran on the stand. No leaks. I didn't put the back inside rivet on the lower plastic cover due to the fact it was tight against the inner case. ( Good design Cat) I've got a week long trip in Maine from 2/6 so that will tell the tale. I'm taking a bottle of chain case fluid with just in case!!!
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Great news. Hope it holds for you. I did a JB weld on mine. It was only a slight weep from a casting imperfection. Mine is holding. Sat in a trailer at -5 the other night. Got about 250 miles on and it’s holding oil. No leaks. I did put a layer of high temp silicon over the JB.Buttoned up the chain case, filled with 16ozs. of fluid and ran on the stand. No leaks. I didn't put the back inside rivet on the lower plastic cover due to the fact it was tight against the inner case. ( Good design Cat) I've got a week long trip in Maine from 2/6 so that will tell the tale. I'm taking a bottle of chain case fluid with just in case!!!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Hope we have more snow by feb..6th than we do now,depends on where in maine you plan to ride,northern maine caribou north has good conditions now,but cant say how long those will last? We need more snow.I'm sure I didn't hit any thing. Removed the plastic piece under the chain case, no marks in 8,300 miles. It will be a warranty job, just hope the dealer can get parts. Leaving for Maine on 2/6 for a week!
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
How free flowing would anybody think the breather tube on the chaincase should be and if it was plugged what would be the weakest leak point
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
You over fill the case it will come out that breather tube. I would say it’s as free as can be ?
