Crankcase oil drain plug size
Cubby
South of Winnipeg, Manitoba CANADA
Canada
2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Does anyone know the size of the crankcase oil drain plug? I think its an M10 x 15mm.
I was changing the oil and stripped the hex head trying to loosen it. Strange since I know I torqued it properly last time to 11 ft lbs.
Anyway I want to replace it with one that has a regular bolt head.
Thanks in advance.
Yes, the bolt is a M10 x 1.25mm pitch x 15mm grip/thread length. Luckily I have not stripped one out, but could totally see it happening so I also replaced the socket head bolt with a hex head.
I did order the OEM Yamaha oil drain bolt. When I picked it up at the local Yamaha dealer they actually found a proper hex head bolt with the exact measurements I needed (M10 x 1.25 s 15.5mm) in a bag of spare parts. No charge! Thanks to Wildwood Yamaha.
