harm67
06 apex gt stored outside since last winter some fuel in it. battery is strong just don't wanna fire! any ideas where to start?
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
Fresh fuel first
harm67
check!
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
First I would hook up a set of jumper cables to a car battery, if the battery is not putting out 12.4volts (I think is the right number) it will not start it will crank fine. Check for a plug exhaust, pull the plugs they maybe foul with the cranking and not starting.
seafoam the gas for condensation in the tank and i assume that you did hear the fuel pump run before you tried starting it?
i have seen partly full gas tanks accumulate almost 1" of water in the off season at my house and i live right on a lake.
Pull the fuel line off the throttle and crank it and see if you are pumping fuel? Then check for spark... how many miles?
tomanytoyz
Oh boy. does it want to fire,any signs of life ,gauges light up at all?
Deedge11
- Nov 23, 2014
- 2006 Yamaha Apex
It's your crank position sensor or stator. All one unit. Mine would do the same thing, just crank and sputter a bit but would not start. Same sled
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Could just be a stuck injectors due to our high quality gas these days! Experienced this on a nytro a few weeks back. Had spark, fuel pump ran and it would not start. Mine freed up on there own after letting it sit for a few hours. Had a customer this week that had one injector stuck. He said he ran some sea foam through it and it freed up.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Im with you.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Dump a little fuel in the throttle bodies and see if it fires off.
harm67
it just cranks no sputtering...its been cold the last few weeks and i have no place to warm it up, im gonna try some fuel anti freeze.It's your crank position sensor or stator. All one unit. Mine would do the same thing, just crank and sputter a bit but would not start. Same sled
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
If its the crank sensor you can find it alone on line and replace yourself if your a little bit handy.
attak 06
Check the relay for the fuel pump on the brake side just above the foot rest. If it been cold and possibility got wet, it's worth a look. Happened to me before. I removed the relay, warmed it up in my hands and it fired right up
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Fuel pump relay is on the clutch side and I'm assuming that he has already checked that.
