GAS
- Feb 21, 2018
- Quispamsis
- 2017 Sidewinder RTX, TD SQ exhaust, TD tune bundle. Dash flash, TD/Dalton clutch kit, 225, 1.57 mega bit studs. Pilot skis.
Hi
Anyone replace their sec dalton spring after the recall. When they sent me my new spring they recommended I wrap it 6-2. They said that is the same force as the 6-1 position with the old black and orange spring. Anyone running at 6-2??
BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
Been running this spring all season at 6-2, works well, stock helix, TD max spool 16 with stock muffler
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Yep 6/2 and 6/3 with tune works nicely with more power.
Testing the white now and need more miles to confirm if Ill stick with that.
Dan
Dan
theewarrior
I’m set on 6/1 new dalton b/o seems fine , should I change to 6/2?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Has alot to do with tune/power....and how/where you ride IMO.I’m set on 6/1 new dalton b/o seems fine , should I change to 6/2?
I ride mostly tight trails, and 6/2 worked well overall....6/3 was great but a tad hotter, but still quite good temps.
With bigger tunes and wide open pulls, and deeper snow ect....guys are trying heavier setups as they can slip the belts in these type of conditions with big power.
Dan
GAS
- Feb 21, 2018
- Quispamsis
THANKSYep 6/2 and 6/3 with tune works nicely with more power.
Dan
- 24K
