Diagnostic Numbers?
MIK123JE
Does anyone know what the diagnostic numbers means when you push the select and mode buttons together? I know that 64 means roll over, i know one tells fastest the sled has went, and one tells if your throttle opens all the way. Just wondering if anyone knows, thanks!
No body knows about this? Go ahead and try it for yourselves. Hold the selec and reset buttons down at the same time, continue holding. Turn key on and continue holding for 10-15 seconds. You will enter the diagnostic mode. The first diagnostic is the throttle position sensor. Open throttle and you will see if it hits 100%. The second I believe it how fast the sled has been.
Cool!Is also this one for adjusting fuel.
I wonder if if would be a good idea to bump up a point or two richer if you have an exhaust and the intake mod.
Anyone know these points stand for? As in how much ricer is 1 point?
Also does the phazer have an 02 sensor? Is it self regulating?
Thanks,
-Steve
No O2 sensor.Would need a AFR meter to check.I believe they are rich from factory off idle at least and exhaust would help correct this.Not sure about whole range though.
I wouldn't be surprised if not, very sophisticated stuff,, not sure if I was supposed to even tell about this option. It is like a black box for a sled.
mike
Well I have a factory service manual, and it makes no mention
of "diag mode" unless of course I'm blind... I'm sure its available to dealers on their electronic documentation.
