TT
It would have been fun to see how the Bender kit would have worked with Huricanes boost carb springs.
I know other people have tried different Holtzman carb springs with the Bender kit without any luck.
Dave any input after the tuning the Bender kit on the dyno?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
I learned a little bit about the Bender kit myself. I see some pro's and con's.I think that the Powder lite kit has alot more engineering in it but I really liked the bleed-off screw that bender used for jetting. The turbo carb springs will not work on the bender ,infact, a softer then stock spring would work better to help richen up the lean mids on the Bender.
Be carefull Guy's,,,the springs are part of a over-all package and need to be install with a change to the bleed-off screw size and also a needle clip position change.Possibly a main jet change also. Over all, I believe that it is possible to make the air-fuel ratio good from idle to wide open throttle on a Bender set up
TT
Thanks Hurricane!
Blue shadow
How many of you plan to run the meth kit before the snow comes?I know I will .Thanks bender srx for the info from the dyno.You will be having lots of fun racing the other brands this year.
1xr
Blue shadow said:How many of you plan to run the meth kit before the snow comes?I know I will .Thanks bender srx for the info from the dyno.You will be having lots of fun racing the other brands this year.
I know I will be useing a kit this winter on a simons apex turbo, as long as I can find room for the tank.
I have a meth kit on my car now, I can almost double the amount of boost on pump gas. Well worth the money.
BenderSRX
- Nov 29, 2006
- Constance Bay Ontario ( Ottawa )
- 2013 Yamaha Nytro RTX
No problem Blue Shadow. I can't wait to ride, this time of the season is so hard were so close but yet so far away, a day feels like a month. So what did you do this year for a motor i read last year you lost a rod and the motor was toast?
1xr my tank is installed in the pouch at the rear of my apex seat and the pump is right near my steering coloum
Blue shadow
I have a another one in and ready to go .10 to 1 low comp pistons ,stock head gasget ,114 lob centers ,2 1/2 inch down pipe ,ported wasgate ,meth injection,and 22 psi with some race fuel,X D -16 a/f gauge,and 100 pounds remove from sled.Let it snow
snowy1
can anybody tell me how long a 3 quart bottle will last at wot, I will only be using it on high boost above 18 lbs. on a nytro with three nozzles in the throttle bodies.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
Rule of thumb,,,,if your an animal on the throttle,,,,1 tank of meth to 1 tank of gas
snowy1
thats better than I thought, that works for me.
BenderSRX
- Nov 29, 2006
Blue shadow said:I have a another one in and ready to go .10 to 1 low comp pistons ,stock head gasget ,114 lob centers ,2 1/2 inch down pipe ,ported wasgate ,meth injection,and 22 psi with some race fuel,X D -16 a/f gauge,and 100 pounds remove from sled.Let it snow
Blue that Rocket is going to be like minimun 350HP
1xr
snowy1 said:can anybody tell me how long a 3 quart bottle will last at wot, I will only be using it on high boost above 18 lbs. on a nytro with three nozzles in the throttle bodies.
It depends on the nozel sizes. On my car I have the 375ml per min (400ish whp) nozel in it. It will use up it up if you are into the boost alot.
For our sleds the kit must have 4 yellow 60 ml min nozels.
snowy1
1xr said:snowy1 said:can anybody tell me how long a 3 quart bottle will last at wot, I will only be using it on high boost above 18 lbs. on a nytro with three nozzles in the throttle bodies.
I have talked to Huricane and thats what he suggested, only 3 nozzles though as I am running a nytro.
Blue shadow
The kit I will receive for my rx 1 has two nozels .Huricane said to put them in the middle of both carbs about 1 1/2 back on the intercooler.
happyhour
- Feb 15, 2007
snowy1 said:1xr said:snowy1 said:can anybody tell me how long a 3 quart bottle will last at wot, I will only be using it on high boost above 18 lbs. on a nytro with three nozzles in the throttle bodies.
when I talked to derick at snow he recommended running just one nozzle on my i/c inlet side he mentioned with the velocity of the air through the intake would be more than enough to mix through the i/c I asked him about running separate nozzles and he said that he didn't think it was necessary the only problem he said I might have would be mixture pooling in the bottom of the i/c now I am getting that feeling I need to change this to a four nozzle set up can someone explain why I need to run 4 versus 1 nozzle with one nozzle it would be less prone to problems my thinking any ways I am also running the safe injection with the solenoid on the waste gate
