apexgt4life
Service a fleet of viper rtx from 15 to 16 ish
All have
Kimpex rear 2 up seat
4 position torsion block
Duell rate factory front spring
All are eating duponts at bend in less than 800 miles in decent conditions
No complaints with handeling
What is causing this.
Is it 2 up riding with the max torsion spring messin with geometry?
Limiter strap is out too
No trying to change settings as they handle good
Thoughts?
All have
Thoughts?
smokingcrater
How much and were are they wearing? Yamaha's tend to wear a spot near the front quickly, but it hits a certain point and kind of stops
apexgt4life
All the way to rail at bendHow much and were are they wearing? Yamaha's tend to wear a spot near the front quickly, but it hits a certain point and kind of stops
on an older sled i had to suck up the limiters 1/2" tighter to get the slides to quit wearing at the bend even with marginal snow wheels in fresh snow. it now wears to a point and stops.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
I have recently been able to buy the DuPont slides with the hard inserts. I have had them on order for three years and in April I was notified that they were in. I would check to see if your local parts source now has them available they last about 4-6 times the miles
as stock slides. Once you correct the excessive wear they will cure any other excess wear issues. They are expensive at $100 apiece but we’ll worth it for the trouble free miles and reduced maintenance required.
apexgt4life
Yes have been running duponts but there are eatin at bend just as quick ad regulars. Rest of it is good just gettin chewed at bendI have recently been able to buy the DuPont slides with the hard inserts. I have had them on order for three years and in April I was notified that they were in. I would check to see if your local parts source now has them available they last about 4-6 times the miles
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
I had that problem with my Sidewinder LTX SE as well (even with Dupont slides) due to the need to run the track so tight so that it doesn't ratchet at 90+mph. I installed the Schmidt Bros Hyfax saver kit and it seems to be working well. It greatly reduced the wear at the bend.
Hyfax – Slide Saver Wheel Kits | SchmidtBrosMotorsports.com
This marginal snow wheel kit saves the hyfax from being wore down at the arch of the rail where hyfax wear is greatest. You will spend less time and money replacing hyfax and achieve a higher top end speed.
www.schmidtbrosmotorsports.com
apexgt4life
Ty which one you get. Appers all different kits. Was thinking maybe just extra outside wheels at bend?I had that problem with my Sidewinder LTX SE as well (even with Dupont slides) due to the need to run the track so tight so that it doesn't ratchet at 90+mph. I installed the Schmidt Bros Hyfax saver kit and it seems to be working well. It greatly reduced the wear at the bend.
This marginal snow wheel kit saves the hyfax from being wore down at the arch of the rail where hyfax wear is greatest. You will spend less time and money replacing hyfax and achieve a higher top end speed.www.schmidtbrosmotorsports.com
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
I got the kit for the Sidewinder (all Procross). There is only 1 kit for those. It is a shaft with 2 wheels that are between the rails. You have to scroll down to the bottom of the page and click on the link for the Sidewinder to see the pic.Ty which one you get. Appers all different kits. Was thinking maybe just extra outside wheels at bend?
This is the pic that you will see.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
Here's a pic of the kit installed on my rails.
Dewaddict
You've probably fixed your problem by now but just in case... I ran into the same problem on a 121 track that I extended. Finally stopped after I took in some limiter strap and compressed the springs on the skis some to take pressure off the front of the skid. Still handles fine and the excessive wear stopped.
- 7K
