ECP and Glasspack can live together under one hood!!!
Ok, my glasspack is being welded onto the stock Y pipe this week.
Tundra, could you please provide me a to do list for the modification?
Frosty
well well well,
I played with needle, bad idea , they were at 4, now at just little bit under 5.
Listen to my sled, you will understand
http://media.putfile.com/rx-1-poudreuse
before the midrange was almost perfect, my error to play with needle.
And, i put 165 too, :Rockon: , 165 are the ticket.
Frostbite, i will give you a list tomorrow morning, im comming from a ride, and am tired big time
Frosty,
You need to support your seat ( i have a nice seat support if you want )
You will have to look at your clutching (mine went off after the Single pipe vs only the ECP) Went from 135 to 128 on total force
Other than that i say follow the recommendation from Supertuner for the Jetting size. I found that 170 work great at lower elevation 0 to 500 feet, but too rich at 1000 and more. Now im 165 main jet and no bugging when flooring the throttle. Im at 4 positions for needle and work great, i were to high this weekend, almost 5 and got some major bogging down low.
Other than that, sled seem to react more at weather change than with the stock exhaust, this is the only downfall.
tundra
Thanks Tundra.
I will use your setup but I ride from 4 to 7,000 feet. What do you suggest for mains 160 or 165? I do have a Holtzman ATACC on my sled so it may help.
I will give it a try but keep my White Knuckle QC-1 just in case.
Yes, I would be very happy to use your seat support.
Thanks Dude
Frosty
Freddie,
I have 160 mains in the sled right now and with the White Knuckle QC-1 exhaust it's a little rich on the lower ned of the spectrum and nearly perfect above 8,000 RPM.
Perhaps I will give the 160s a whirl and give them a try before I swap out the mains.
Will the fuel screws or pilot jet sizes need adjustment? I think mine are at 2.0 turns out from seated right now.
Frosty
Frosty.. I was was running the 160MJ at 6000' and had lots of booging on my climbs. I was only able to pull 9800 on hard pack snow and it would drop to 85-9000RPM in the soft deep snow. So I was really hurting for power.
1-2' of heavy wet snow and 0 degrees temp. Hood was covered with snow and sled would load up and bog. No snow under hood but it deffinatly needed air. I would like to know if changing the air screws would help and also needle settings?? Only 2 days to ride so I didnt play with anything.
Interesting Culvert!
With my shockwave and the white knuckle I can now pull 10,500 WHILE CLIMBING! Before I was lucky to pull 9,500 or 9,600 while climbing.
Frosty
i find a part of the low speed bogging i had last week.
i found there was missing a small spring that goes over the needles.
But i cant find only the spring, i need to buy the all package :o|
Anyone have this little spring left that i can buy ?
Tundra, I wonder if a spring from a ball point pen would work? Any light spring will work as this just holds the needle in place.
Might be worth a try until you get the regular one.
4-Play
Frostbite said:
Freddie,
Frosty
I would imagine you mean going to a 155 main jet? If you have 160's in now why would you change to 160's again?
Freddie, I apologize if I was unclear. Yes, I have 160 mains in my sled now.
Yes, I also plan to try the 160s with the single pipe before (and if) I swap to the 155 mains.
That's what I meant by this statement in the above post.
"Perhaps I will give the 160s a whirl and give them a try before I swap out the mains".
Tanks for all you do for us.
Frosty
Ok, I'm ready to try the single pipe.
I will try 160 mains (probably tto big but I have a Holtzman ATACC on my sled).
Needles in the #4 posiiton.
Fuel screws 2.0 turns out
I guess we'll see how this works at 4-6,000 feet.
Frosty
