Kidster
- Jan 24, 2016
- Lorette,Manitoba
- 2010 Yamaha venture rs
I just bought a 2010 Yamaha venture rs and have ridden it for a weeks all but put 200 km yesterday and as I pulled up to the cabin the sled started to bog and the lights went out on dash except the high beam light will come on also have no tail light or brake light and the back up beeper is not working , but sled will run checked fuses all look so not sure where to check now any help would be great. Thx
Have you checked all the fuses? There are some beside the battery as well.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
load control relay
Kidster
- Jan 24, 2016
- Lorette,Manitoba
I checked fuse on right side of sled never saw any by battery, only bad fuse I had bad was the 3 amp fuse for back helmut plug that is wired into tail light . Where is load relay located , thx for all the help
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
just above the right toe hold and below the reverse lever. Remove vented plastic panel.
Kidster
- Jan 24, 2016
- Lorette,Manitoba
Thx for all the help , I will check that out and let you know , I wired the passenger helmut in with the tail light power feed do you think this would have anything to do with my problem
Kidster
- Jan 24, 2016
- Lorette,Manitoba
All fuses are ok including ones by battery and changed the load control relay this didn't fix the problem , as there anything else that I can checks , and thx for all the help.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Bad battery? One cell in the battery going bad? Pull the battery and have it load tested?
Kidster
- Jan 24, 2016
- Lorette,Manitoba
Starts sled no problem , headlights work and both hand and thumb warmers work fine and battery shows 12.6 volts seems odd that it could be battery but I don't know what else to check thanks for the suggestions
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Bad battery or possibly not charging. I'll pull up the wiring schematic tonight to look for other possible causes.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
what's the voltage on the battery when it's running? should be around 13.5 volts
Kidster
- Jan 24, 2016
- Lorette,Manitoba
Kidster
- Jan 24, 2016
- Lorette,Manitoba
When running I have just over 14 volts
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Bad regulator Grizz?
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
14 volts is probably OK. The load control relay is powered by the key switch and controlled by the ECU. Check the key switch connector for corrosion.
