rickyracerrx1
- Nov 24, 2008
Found today I have a spun main bearing.( long story on how I found it)
But I need to remove the motor. I have every thing off and apart but I am hung up on the rear mount. I have the long bolt out but I can not get it to move. I would like some help here. Please. Front of the motor will move up and down and swing on that rear mount.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
There is a jamb nut on that motor mount, you have to loosen the adjusting nut and it will pop right out.
rickyracerrx1
- Nov 24, 2008
thats what i was thinking but I cant get it to move.
bdm
I do NOT speak from experience (other than trying to figure out dealer screw-ups) but I think that Kinger may be referring to the engine adjusters - they are threaded sleeves that screw into the mounting tabs, there are at least 3, make sure that they are loose.
I apologize if I am incorrect.
rickyracerrx1
- Nov 24, 2008
Thanks guys!!!!!
bdm
rickyracerrx1 said:Thanks guys!!!!!![]()
Hey Ricky, did you get it out? If so, what was the problem?
