swampcat
What is a average running temp for this engine? What temp does the thermostat open ? I tried searching, but came up empty. Thanks.
fourload
In normal conditions mine runs between 167-172. Not sure about the thermostat opening temp but I would guess it opens about 170. Wonder if a cooler thermostat would help power?
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Average running temp, in great cooling conditions, running easy, so as not to fluctuate temp much, has been 172 on mine.
When the thermostat opens, can be easily determined by starting a cold sled and simply watching the temp on your gauge. It will continue to rise until the thermostat opens, at that point it will loose 3-5 degrees, and then slowly start climbing again. My thermostat opens at 167-168.
Turboflash
- Mar 18, 2019
- Southern MN
Stock spec says stat opens at 75 degC = 167 degF.
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
X2 spot on for mine too!Average running temp, in great cooling conditions, running easy, so as not to fluctuate temp much, has been 172 on mine.
