infernobuster
- Oct 27, 2014
- Whitby, Ont
- 2015 Viper LTX LE
Ive got a 2015 LTX LE and wondering what everyone else is showing on dash when running for engine temps?
Mine shows just over 1/2 and sometimes reaches 3/4 when out on the trails riding around at 60 - 70 km/h.
Normal, or should i be looking into this further?
rbell14
If I recall it seems mine is showing mostly 3/4 full bar most of the time. I was curious about the same question.
stingray719
You can make it show the actual temp in numbers on that display.
viperrtx
- Dec 21, 2014
- yamaha viper rtx
Hey inferno if you want to know exact number of your temp. The button to the left of your temp gauge. If you hold it down for a few seconds it will swith to an actual number instead of just the bar. Just a heads up. It's pretty cool.Ive got a 2015 LTX LE and wondering what everyone else is showing on dash when running for engine temps?
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Sounds about right. As stated you just have to press and hold the bottom button on the left side of the gauge and that will also show how many degrees (or Celsius) it is. My personal sled would run 160-170 while moving.
csederlund
I rode in -3f to 11f temps this last Saturday and mine was running a consistent 163 degrees with factory air box with no mod.
stingray719
Light comes on at 213 and at 223 it goes into limp mode, would be hard if not impossible to burn a Viper down.
rbell14
Awesome - thanks. I actually think I remember seeing that but never checked it again. I will be running with actual numbers as the bar is too vague.
infernobuster
- Oct 27, 2014
- Whitby, Ont
- 2015 Viper LTX LE
Thanks will try that trick when im out again on it ..
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Mine ran at 163-194 drops quickly when good snow I like the #'s display if I remember it is about 2/3 of the bar.
09nytro
I run at 169 pretty much all the time
Nick Torraville
- Nov 9, 2014
- Newfoundland, Canada
- 2014 SR Viper XTX SE
Any time I'm in good snow, it'll read 74-79° C. The most I've seen it read when in terrible snow conditions was 95°C.
mtotguy
- Jan 20, 2011
- Montague, Michigan
- 2016 Rush 800, 2014 Viper RTX, 1983 Excel 3
True enough. I was running in deep powder last week and mine started to miss. I assumed I was getting powder into my intake and kept riding thinking it would clear up. It finally got so bad it would hardly run. That's when I finally noticed the alert light and the pegged temp gage. I had been thru this before on my Nytro so I rolled the sled on it's side and looked at my heat exchanger. Sure enough there was an ice dam between the track and the exchanger. I busted out the ice, let the motor cool down and have been riding with no issues ever since.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
I noticed that ice dam on the last 2 M8's I have rented.... not that they overheat, but the ice build up on the front exchanger.
- 36K
