Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Thanks, Iam sure after riding my 2024with EPS its going to have to go on the 2017..$1100 to $2000 depending where you buy and if you buy Yamaha (cheaper) vs Arctic Cat parts.
Big Pussy
- Apr 12, 2016
- Woodstock, Ont
- 2015 XF7000 LXR
Anyone with a Sidewinder and a Viper can tell me if the Viper air box is going to be a problem either for the steering unit or the upper steering shaft ? Seriously thinking of putting this on my 7000.
Tcat100
Folks there is one more part that is important. It stops the steering post from over turning (and straining the EPS). It goes under the 1605-154 new shorter block and the steering post bottoms out on it.The "how to" is very involved. If I do another conversion, I'll take some pics and measurements to post. Sorry guys...
each Qty extended 1705-667 EPS 1235.16 1 1235.161605-211 plate 15.82 1 15.821705-616 coupling 102.81 1 102.811705-614 post 88.16 1 88.161605-226 stop, post 9.87 2 19.741605-154 block, mounting 4.35 1 4.351605-212 bracket 16.80 1 16.801686-927 harness 567.67 1 567.670423-577 u-nut 0.55 4 2.202623-063 screw 2.07 4 8.288409-026 screw 1.96 4 7.848020-045 screw 1.23 2 2.468047-366 nut 0.55 2 1.102623-202 nut 1.52 1 1.52 2073.91
STOP,MTG-STEERING POST-LOWER EPS
STOP,MTG-STEERING POST-LOWER EPS Part # 1605-226 Arctic Cat OEM Part
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Tcat i just looked up that part and it shows that only one is needed but your parts list shows qty of 2 ?Folks there is one more part that is important. It stops the steering post from over turning (and straining the EPS). It goes under the 1605-154 new shorter block and the steering post bottoms out on it.
STOP,MTG-STEERING POST-LOWER EPS Part # 1605-226 Arctic Cat OEM Partwww.countrycat.com
Tcat100
you only need oneTcat i just looked up that part and it shows that only one is needed but your parts list shows qty of 2 ?
YamaSpark
- Sep 21, 2017
- Greenfield, Minnesota
- 2016 SR VIPER S-TX 137 DX
I will be installing factory SW eps on my Viper, so I've studied both sleds very closely, and it looks to me like everything should just clear the airbox. I believe that, at the very most, the front RH corner of the airbox edge may need to be trimmed slightly to clear the eps motor, but I don't think so.Anyone with a Sidewinder and a Viper can tell me if the Viper air box is going to be a problem either for the steering unit or the upper steering shaft ? Seriously thinking of putting this on my 7000.
Fingers crossed!
Big Pussy
- Apr 12, 2016
- Woodstock, Ont
- 2015 XF7000 LXR
Please take some pictures of the brackets in the chassis without the steering booster and also get good hole drilling measurements and/or a drill template. I will have the sled apart this summer to have the driveshaft spray welded for a bearing press fit. Going to make installation puller to get it togetherI will be installing factory SW eps on my Viper, so I've studied both sleds very closely, and it looks to me like everything should just clear the airbox. I believe that, at the very most, the front RH corner of the airbox edge may need to be trimmed slightly to clear the eps motor, but I don't think so.
Fingers crossed!
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE
18 Winder LTX 50th
97 SX Vmax 600 (red)
Started the EPS install on my 18 Sidewinder. I'm about 8 hours in and have the EPS unit, steering coupling, drag link, steering post, steering stop and joint/handlebars installed/back together. I've taken my time on this part of the install and glad I did. Read Tcats tips on what needs to be removed to make room in the tub for this install...it is tight. Next mark location for the 3 holes that need to be drilled using Tcats template. Nope not gonna work, after double checking measurements are correct, I had 5 13/16" heavy center to center for the mounting plate and center to center on the mounting plate is 5 3/8". What I figured out is the 18 lower panel is slightly different causing issues using Tcats measurements. So, I got some nuts and bolts (tight fitting) and assembled the plate and bracket, put the spring nut on the bracket for left side mount. Put the assembly in the tub and installed left side bolt. Its tight but using a punch I was able to mark each location one at a time. To make sure I had the correct location I drilled a 1/16" pilot hole from inside the tub, put the spring nut on, put the plate and bracket back in, installed the left side bolt, pulled the assembly tight to the tub and from the outside of the tub sent the drill bit back through to verify it came up through the spring nut. Took a little more time but it was worth the effort getting those holes drilled correctly. I will take some measurements when I have a minute to share. Next is the wiring, I have all the connectors just waiting on the twisted wire that I just ordered from McMaster Carr to make the jumper harness. I think Richard rated this a 9/10 on the difficulty scale, I'm going to put it at a 6/10. If you have ever replaced a front heat exchanger you know what a 9/10 on the difficulty scale is. Overall, it's not hard just tight working quarters.
I will pay someone a reasonable price per hour If someone is interested after helping or completing a few conversions.
Install is pretty easy. I have 3 I’m doing. Getting parts and building harness is the worst part.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Are you doing a post on the install?Install is pretty easy. I have 3 I’m doing. Getting parts and building harness is the worst part.
Yes sir. I will have a post and making a video on both install and building the harness. Just waiting on parts. Once I have everything I’ll be able to start the project.Are you doing a post on the install?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Thanks!Yes sir. I will have a post and making a video on both install and building the harness. Just waiting on parts. Once I have everything I’ll be able to start the project.
Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
What is the time frame now on getting all the parts? Weeks or months?Yes sir. I will have a post and making a video on both install and building the harness. Just waiting on parts. Once I have everything I’ll be able to start the project.
Few things I am missing could be a month. But it was pushed out once already.
- 6K
