earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
ECU I would say no. Harness you can make which I would considering how precious that harness is in the parts catalog.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Awesome job with this earthling
So for 2017 do I need harness and ECU ? I was on Partzila and noticed they have stock on PS motor showed 2.
Part numbers and links supplied by TCAT added to spreadsheet and pdf file so everything is in one spot.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Awesome I only read this post 4 times now lol awesome job guys.Part numbers and links supplied by TCAT added to spreadsheet and pdf file so everything is in one spot.
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Thank you for all your workPart numbers and links supplied by TCAT added to spreadsheet and pdf file so everything is in one spot.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I may have 2 of these to do next fall.....
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
I will be doing mine in the next few months and will try and post as much details as possible. Big thanks to Tcat100 for getting this done..A step by step would be awesome. Not afraid to tackle this but some general steps would be perfect. I have a 22 so much easier from what I can tell.
On a side note I didn’t think the PS unit was that big, comparing it to my grizzly eps it’s considerably bigger.
super1c
Moderator
- Apr 10, 2010
Question on parts? I’m getting my parts list together per supplied PDF list. Are not the first 9 parts listed parts we already have on our existing sleds? Or are they a different size or something.
I believe they are!Question on parts? I’m getting my parts list together per supplied PDF list. Are not the first 9 parts listed parts we already have on our existing sleds? Or are they a different size or something.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
You believe they are different or parts we already have on the sled are good?I believe they are!
super1c
Moderator
- Apr 10, 2010
Did some cross reference on numbers. All but the riser ( I’m assuming because of color) and #7 rear part of “steering bearing” are the same 1-9.
super1c
Moderator
- Apr 10, 2010
Only number 7 appears to be different part per number.You believe they are different or parts we already have on the sled are good?
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
I didn't order that stuff for my 18 conversion but maybe I should.
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
I'm going to do the same, just gotta be sure.Did some cross reference on numbers. All but the riser ( I’m assuming because of color) and #7 rear part of “steering bearing” are the same 1-9.
Sorry, they are the same as what you currently have.You believe they are different or parts we already have on the sled are good?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
In the spreadsheet (not the pdf) there is a hidden column G which shows you parts (marked with x) which are common to the existing sled. The only unknown is quantities which may/may not be the same as you already have. The total value of the common parts is ~$73.00, its mostly small stuff
Here are the first 9 rows from the pdf, all parts are different, I double checked both the spreadsheet and the pdf, the parts are all unique per row. The spreadsheet actually has conditional formatting on the part numbers, if any part number shows up twice the text would turn red. If you mean that only part 7 isn't a part number that appears in the non-eps sled part list you would be correct, but see above, $73.00..
