YamaSpark
- Sep 21, 2017
- Greenfield, Minnesota
- 2016 SR VIPER S-TX 137 DX
I am near completion on my Viper. The airbox does require minor modifications in two areas: a flat on one corner (screw clearance), and a "D" shaped hole just above the flat (for eps motor power plug clearance).Who has done this to Viper or 7000?
I want to know if the air box goes back in without interference.
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
So no interference with the radiator? That's great to hear! Was thinking about getting a 7000/Viper for my wife but only if I could do the PS upgradeI am near completion on my Viper. The airbox does require minor modifications in two areas: a flat on one corner (screw clearance), and a "D" shaped hole just above the flat (for eps motor power plug clearance).View attachment 176672
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
"Complete" is operative word. In this thread I think there is a list, but since it was issued, there have been additions/changes. The original list is pretty complete but there are changes. Also, there are templates on where to drill holes, etc. Electrical side may not be quite as clear as mechanical side. And, there are electrical wiring variations between some sled models.
VIdeos would be a huge help.
The link I shared earlier (the original list) is complete and if there are changes (part numbers) or additions, anyone can download the spreadsheet and make those changes or even make them in place. I keep a separate list in case someone screws something up. Or, if someone can point me at the changes I will update the list and turn it into a pdf for those that just want to print it out.
YamaSpark
- Sep 21, 2017
The Viper install is extremely easy, due to lots of room and the opening in the front of the bulkhead. I was able to mount the eps motor to the mounting plate & bracket, and lower the assembly into place. I did have to temporarily remove the sway bar however.So no interference with the radiator? That's great to hear! Was thinking about getting a 7000/Viper for my wife but only if I could do the PS upgrade
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
wow, tightening that coupler bolt was the hardest part on the turbo install! this looks easy!The Viper install is extremely easy, due to lots of room and the opening in the front of the bulkhead. I was able to mount the eps motor to the mounting plate & bracket, and lower the assembly into place. I did have to remove the sway bar however.
Turboflash
- Mar 18, 2019
- Southern MN
Yes, thank you kindly!The link I shared earlier (the original list) is complete and if there are changes (part numbers) or additions, anyone can download the spreadsheet and make those changes or even make them in place. I keep a separate list in case someone screws something up. Or, if someone can point me at the changes I will update the list and turn it into a pdf for those that just want to print it out.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Ok, the spreadsheets have been updated.
Parts List which includes the complete parts list as well as the unique parts list, @Tcat100 's bolt measurements, and @DennyTuna 's pin information
EPS Upgrade Spreadsheet
EPS Parts list PDF in a couple of printable formats
Letter Format
Legal Format
Here is a checklist for purchasing, note that you only absolutely need the unique items (U), You may need some of the common items (x)
Purchase Checklist
Toms EPS Wiring image for the connectors
EPS Connectors
If there are any issues, pls let me know
Letter Format
Legal Format
Purchase Checklist
EPS Connectors
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Nice work earthling!
Turboflash
- Mar 18, 2019
- Southern MN
Great job Earthling!
Back in the day when the factories gave a s&#t, they might have done something like this to sell as a factory kit. Not any more.
This site is amazing that you guys put this together an offer it free to our members. Outstanding!
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Good time to become a lifetime member!!!!Great job Earthling!
I have done 3 Sidewinders with great success. Here is all the info you need and the install video. If you have any questions please ask them in the new thread.
ty4stroke.com
2017 Sidewinder EPS Install Video and Info
Here is the Video of the install: Step by Step information how to install EPS (Electronic Power Steering) on your Yamaha Sidewinder 2017-current that don't originally have EPS. There are 2 PDF's (PNG) shown, one is the info needed for you to build your own harness and the other is a the...
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
My brother-in-law is looking to add EPS to his 2023 LTX SE. Would he only need to order the OEM parts from the list that DO NOT have the X in the "Common Parts" column (and wouldn't need the jumper harnesses or related parts)?
Go to my list on the above link. He needs everything but the harness that I made.My brother-in-law is looking to add EPS to his 2023 LTX SE. Would he only need to order the OEM parts from the list that DO NOT have the X in the "Common Parts" column (and wouldn't need the jumper harnesses or related parts)?
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
So were it only the LTX LE models that came with EPS in 2023?My brother-in-law is looking to add EPS to his 2023 LTX SE. Would he only need to order the OEM parts from the list that DO NOT have the X in the "Common Parts" column (and wouldn't need the jumper harnesses or related parts)?
no there were other models. If you go to parts fiche you will see EP in the model. Those have eps. Like 23 LTX GT, LTX LE, SRX LE, STX GTSo were it only the LTX LE models that came with EPS in 2023?
