yooper1
I am having a cooling issue with my Nytro now that it is super charged. I just got my tunnel coolers from MPI but this is not a quick install, has anyone ever used this, RED LINE WATER WETTER® COOLANT ADDITIVES?
It is suppost to work great? and feedback would be great.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Used it in my Grizzly and it worked great but I am not sure how much it alters the freeze point to use in a sled?yooper1 said:I am having a cooling issue with my Nytro now that it is super charged. I just got my tunnel coolers from MPI but this is not a quick install, has anyone ever used this, RED LINE WATER WETTER® COOLANT ADDITIVES?
Indy
I've used it before I added another exchanger on the rear, didnt help much.
bluesrxman
- Aug 9, 2004
- Lakeville, In
- www.midwaydental.com
I have not used it in a sled but it works great in my supercharged mustang.
yooper1
i am going to try 1/3 of it in the system.
I also see that the over-flow hose might be pinched by my trail tank. It had the pipes from the motor to the header replaced by the dealer under warranty, so I'll pull it and look. The over flow tank is full and the Rad is low so I am hoping that is it.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
yooper1 said:i am going to try 1/3 of it in the system.
That would do it.
Super Sled
- Feb 25, 2009
- Summit X
The stuff does work. But it freezes befoe coolant does, so watch it in really cold temps.
sleddheadd
Amsoil has a new coolant boost, supposed to be better that Water wetter!
http://www.amsoil.com/a/catalog.aspx?zo=1130379
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
i use water wetter in my sleds..
rhoag
Super Sled said:The stuff does work. But it freezes befoe coolant does, so watch it in really cold temps.
This is why I use engine ice instead. I have used water wetter in my bikes and it works but, got tired of draining it every fall. Freeze protection to -27 I now use this. http://www.kneedraggers.com/product/38-CYC-1/Engine-Ice-Hi-Performance-Coolant-12-Gallon
yooper1
How much of this stuff are you adding? My sled is in at night and during the day should be fine. I was only going to add 1/3 of the bottle. Like 4-5 oz. What are you all running?
kevmc
I have used it in turbo charged car for track use. Can't say it made much difference, but it can't hurt. As for freeze point... it is designed for automotive use; Redline is not going to put out a product that is going to alter freeze point. You are adding a small amount with coolant, no different than adding water with coolant. if you are wanting to add 5 oz of redline water wetter than take out 10 oz's of coolant from your system and add equal amounts of water wetter and straight coolant.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
I use it in mine, 2 seasons of riding and I have not seen temp light yet, (2500 mi). Not sure my temp light even works have never had it come on.
yooper1
oh trust me, the temp light works atleast on mine.
- 12K
- 7K
