millstreet
- Dec 6, 2005
- doylestown, pa and old forge, ny
- current - 2018 Sidewinder ltx-le 50th
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
the sweet thing is its quieter than most and will be repackable..
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I like the sound. Any idea if we can run it without adding fuel or a tune?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
no...it requires a tune or fuel from the pc5
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
There is videos of their exhaust on you tube.
The one with the Rage against the Machine song in the background? Kind of takes away from the sound of it.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
plus it isnt a true depiction as i think it was prototype and the actual version is quieter.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
video here;
Thanks bro.....Like it.
uprider800
- Mar 18, 2016
- winneconne wi
- Arctic Cat xf 9000
So I'm guessing it's not just turn the dial and boom more power. Wouldn't you need to clutch for each power increase? Not knocking the product but you need to do things if boost is increased. Maybe I'm wrong! What are the advantages over a tune?
Buster696
I like this setup because it’s a tunable on the trail/on the lake setup. Keep it low for the slower rides and turn it up when you need or want to. Yes, you will need a heavier weight for starters. I turned my secondary up to 70 deg. I then am trying a clutch setup per some information from Aaron at Excell. Regular trail setup will turn 8400ish when dialed down just below what stock boost is at 9lbs, when you turn it up you want the sled to run 8800~8900ish. I’m finding out that my motor likes weight in the clutch and am adding more and more over the past couple days.
shadow44
Any dyno sheets?
Buster696
Just saw this, looks like Excell updated the website with Dyno and Pricing info
http://www.excellmotorsports.com/side_winder_thundercat.html
--Buster696--
--Buster696--
millstreet
- Dec 6, 2005
updated video here;
millstreet
- Dec 6, 2005
Any dyno sheets?
dyno #s stage 1 are here; http://www.excellmotorsports.com/stage1.html
dyno #s stage 2 are here; http://www.excellmotorsports.com/stage2.html
shadow44
Very impressive.
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
I went and checked this stuff out yesterday. That silencer is freaking sick, the quality of the construction, welds, and metal used is sure to impress..
- 17K
