THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Yah that makes sense
The ice is a pain
The ice is a pain
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
This is what is needed for this issue and also keeps tunnel mounted to heat exchanger.
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
what is that wad of stuff where the connection is? nice beefy repair on the tunnel.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
On top of the tunnel is ultra black rtv to seal the tunnel where the hoses are. Also put it between the plates on repair.
4strokes
- Mar 13, 2018
- charlemont ma
while its on my mind, I just changed my hose and found the rear exchanger had tweaked upward from ice chunks and eventually cut the hose from inside. the bungs are like 1/2" apart. I think if I deal with it again, I will chop an inch or so out of the exchanger just at the bung and have it tig welded and use a longer hose. you have to pull the exchanger anyway. should give it the flex it needs. maybe a cover too, but a cover wont keep it from getting wacked out of line. as a bonus the hose could be done without pulling exchanger.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
The forward rivet on the rear heat exchanger is riveted thru the reinforcement plate on top of the tunnel next to the running board support.
This will keep the flex down and keep the ends lined up for the hose.
The covers just protect the hoses from flying ice chunks.
- 7K
