1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
My louvers had bent closed last winter and coil harness next to exhaust received some good heat and started to melt.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Anyone know the connector part number for the harness side going onto the coil?
Hopefully I can pick one up from the parts store.
Turboflash
- Mar 18, 2019
- Southern MN
Wow, never seen that before! You have a header, or did this happen with stock manifold?
IMO, that area of the tunnel needs to be stronger (thicker?) or re-designed so ice doesn't bend all those louvers shut.
Fleecer
- Jun 13, 2014
- 2019 SRX
You sure you don't have exhaust leak?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Header has been on it for a couple of seasons now.
Don't have any exhaust leaks but the louvers were all bent down to less than 50 percent open.
Going to give it a real good check over.
Looking for a link for the connector.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
If you can't find the connector, give me a call, I think I have a wire harness or two that I can rob the connector off of.
