I do not have the 18MM nut with my Expert. Thier website does not show the actual size of the nut. It should be on page 19 of the installation guide that I also do not have. Could someone please help me. Thanks
LazyBastard
What 18mm nut? Can't you just buy one at home depot?
Silverbullet
I'm sure if you called the factory they would send you the parts and a owners manual you need...You'll love the Expert suspension
Its the coupler adjustment nut, item #59 in the installation instructions. I went to every hardware store around and purchased several different nuts with out any luck. I do plan on ordering one at some point, I was just looking to get it sooner as we finally have enough snow to put around the yard.
LazyBastard
You were buying METRIC nuts, right? When you call adboivin, make sure that you try EVERY extension... they really don't like to answer the phone.
Yes, I was buying Metric nuts. Its a M12 and I have tried every pitch I could find from 1.00 to 1.50.
bjowett
The Boivin instructions I have say the nut is M12 x 1.75 thread with elastic flange, which I'll assume is a nylock.
