biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Those would be great, but the exhaust is so low, I don't think you can divert it enough even with a turnout. The kolpins can lay flat, but again, I don't think low enough on the 11+ sleds as the exhaust is so much lower than the older Apex's
YAMMAROB
- Feb 11, 2013
- Dyer, IN
- 2014 XTX Viper Hurricane Turbo,
2015 MTX Viper
Sons: 2009 Phazer Suprecharged RTX Streched to 153
Florida Snowman
- Sep 19, 2012
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Are those the nytro caddies? Can you post a whole side view of your sled please with the cover up? Interesting you got this to fit and from these views looks good....
Florida Snowman
- Sep 19, 2012
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Nice! Did you modify the (L) bracket some to get it to fit? Thanks for the pics. I'm ordering it now
Florida Snowman
- Sep 19, 2012
Part # SMA-8GL73-CD-DY
FX Fuel Caddy Set
Great set-up for sure. 1.25 gal on each side.
Good luck.
FX Fuel Caddy Set
Good luck.
Caveman
- Sep 13, 2012
- New Hampshire
- Yamaha, Polaris, SkiDoo.
Those look great...and they fit on an Apex? Modified? How do they attach to the running boards? Desperate to safely add gas to my XTX. No room to mount the koplin or rotos and with the speeds we're running I'm out by noon. Amazon shows them back ordered until March but might be worth the wait. Any more apex info on these is greatly appreciated.Part # SMA-8GL73-CD-DY
FX Fuel Caddy Set
Good luck.
Mx307
- Dec 19, 2021
- New Hampshire
- 2017 Sidewinder
I know this is an old post but I recently bought a 2011 Apex 144 and am told it gets bad gas mileage. I searched for the caddies above but they don't seem to be made any more. What are people using to hall extra fuel on the Apex 144?
with exh diverters and using heat tape on the can by exhaust, you can run a 2 gallon roto pax or 1.5 gallon klopin on the top of the tunnel extension.
as to hard on gas, depends on trail conditions. if it is soft or fresh snow, count on under or around the 100 mi mark. of good hardpacked trails, pending flipper abuse, i usually get between 110-120 mi per tank of gas and have never run out yet. might be able to push 130-140 mi but i am not that conservative on flipper abuse. have over 22000 mi on the 11 atm and about 6500 mi on the 16. both get ridden together a lot and witch ever one i am riding is usually worse on gas by a couple of bucks every fill up.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
I ran out twice last season on a bagger trip in Quebec with my ‘16 XTX, both times just shy of 200km total. I’d say about 190km is my absolute max to push it.
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
Ya, not hard on gas at all. If you ride with 600 Etec's it may seem so. But ride with 800 cats and you will always be the last guy to fill up.
Both of the Apex's I have owned would only vary if the snow was super deep or wet and sticky. But for the most part pretty solid
RobX-1
- Coldwater, OH
I purchased these from Travis (Barn of Parts) a few years back but just have never got around to installing them. Thought it was a nice alternative than using the rear tunnel.
i haven't really needed the gas i used to carry but there have been runs where i have had the light on for over 30 km when i got to the pump.
yam429
- Jan 18, 2009
- Saint Michael, MN
- 2009 Nytro XTX, 2010 Vector LTX, 1981 SRX 440, 1989 Inviter, 1991 Snosport, 2004 Snowhawk
- Saint Michael
That’s a great idea! I’ve never seen those before. I’ll have to see if Travis has any available.I purchased these from Travis (Barn of Parts) a few years back but just have never got around to installing them. Thought it was a nice alternative than using the rear tunnel.
View attachment 175171View attachment 175172View attachment 175173
