2008 Nytro RTX
The other day I went out to start my sled it was around 15 F out and it would not turn over at all. So I was 100% sure it was the battery,So tonight I go to charge it and just for the hell of it I hit the key and it started right up and I mean right up! WHy would it do that? The nut was loose on the battery so we but it started with it lose tonight so why would it start tonight and not the other day? was it that being lose? COuld it be something more serious? I was just wondering
nytroman20
Was it turning over or was there nothing at all?
2008 Nytro RTX
lol i know if its turning over that means the battery isn't dead lol. plus i said it would not turn over at all
stopdropanroll
Starter relay froze. Tighten you battery connections. Search is your friend.
sleddingfarmer
Its possible the loose connection did it. Or it could have been some moisture in one of the relays. That is a common problem that is talked about on here.
nytroman20
My bad..read it wrong!
2008 Nytro RTX
it didn't warm up that much and I didn't ride it enough this year for the relay to freeze. PLus when you hit the key u heard the motor like move. Like you heard it like do an 1/8th of a turn
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
More than likely it was the loose connection on the battery.
Same issue last weekend on my buddies Doo. Stopped for lunch and nothing at all when we went to leave. After dinner started right up. We got bact to the cabin and took a look and it was a loose connection at the starter. I will say that the only thing I miss about a 2 stroke is that rope on the right side!
2008 Nytro RTX
I hope thats all it was,I would be screwed if it does it to me in the trail
Super Sled
- Feb 25, 2009
- Summit X
Check all of your connections. Battery terminal screws can find ways to loosen them selves.
Nytroman
- Dec 12, 2007
- Prince Albert, Sask
- 2008 FX Nytro
Sounds like the starter relay. I tried to start mine in the fall, not cold at all, after sitting all summer covered in my shed. The relay was still acting up even in those conditions. I changed it and have had no similar issues all winter. Moisture somehow gets into these relays even under the best of conditions. Just a terrible design.
towerrigger
Tighten up your battery terminal screws and put some silicone on the bolts leading to the terminals. This will stop them from coming loose.
2008 Nytro RTX
See when I hit the key the motor turned over ever so slightly,as if the battery was dead. Thats why I am sure its not the relay. Plus I have a real fine screen over my hood vents so no snow gets on them
2008 Nytro RTX
Oh yea,It wasn't throwing a code so I don't know if that would dismiss the relay problem
